Timing Marks |
Timing Marks |
LukeD |
Mar 17 2005, 09:21 PM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
I pulled off the front of my engine today to clean the crap out of everything. Before I pulled the fan and the large cooling duct piece I turned the fan until the timing mark lined up with the notch. After pulling the fan I noticed I have 2 marks a few inches apart, which one is TDC? Also, after lining them up I pulled the cap and noticed that the rotor was pointing to the #4 spot on the cap? This engine has definately been pulled apart, so is this right? Does the fan only bolt on one way? (i forgot to check) I am planning on adjusting the valves with the motor out, just want to make sure everything is setup the way it should be.
Luke D |
Rhodes71/914 |
Mar 17 2005, 11:55 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Did it run before you started taking it apart? Must have been fun timing it with the dizzy off like that.
Lo-Fi Version | Time is now: 17th June 2024 - 10:12 AM |
