Round Fog Lamp Exploded View, Where do those spring clips go? |
ChrisFix |
Mar 20 2005, 04:36 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
I've been restoring a pair of pre '75 round OEM fog lamps I bought used and in pieces. I've cleaned and repainted everything, and with the help of Karl's repro seals am ready to reassemble.
I'm guessing the wire spring clips are supposed to hold the lens/reflector assembly to the front bezel, but haven't figured out how they accomplish that task. Also, does the seal go around both the lens and reflector, holding them together as an assembly? Any guidance or links to an exploded view? Thanks!! |
jfort |
Mar 20 2005, 07:36 PM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
i cut out the bottom of the hole, started the bolt, slid down the mounting bracket and then tightened it with a ball-end hex key. only way i could figure to do it without removing the bumper.
Lo-Fi Version | Time is now: 8th June 2024 - 11:11 AM |
