Round Fog Lamp Exploded View, Where do those spring clips go? |
ChrisFix |
Mar 20 2005, 04:36 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
I've been restoring a pair of pre '75 round OEM fog lamps I bought used and in pieces. I've cleaned and repainted everything, and with the help of Karl's repro seals am ready to reassemble.
I'm guessing the wire spring clips are supposed to hold the lens/reflector assembly to the front bezel, but haven't figured out how they accomplish that task. Also, does the seal go around both the lens and reflector, holding them together as an assembly? Any guidance or links to an exploded view? Thanks!! |
ChrisFix |
Mar 20 2005, 08:38 PM
Thank you, but no. I mean the bolt that holds the mounting bracket to the bumper. My fogs came with all the hardware including two hex head bolts to attach the mounting bracket to the car that are too large in diameter to fit through the holes that exist in the bumper (bottom of the grille cut-out) - unless there is somewhere else this is supposed to attach. Is the mounting bracket attached with a nut and bolt through the hole in the bottom of the grille cut-out, or is there a blind nut that I'm not seeing? |
Lo-Fi Version | Time is now: 8th June 2024 - 06:30 AM |
