Round Fog Lamp Exploded View, Where do those spring clips go? |
ChrisFix |
Mar 20 2005, 04:36 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
I've been restoring a pair of pre '75 round OEM fog lamps I bought used and in pieces. I've cleaned and repainted everything, and with the help of Karl's repro seals am ready to reassemble.
I'm guessing the wire spring clips are supposed to hold the lens/reflector assembly to the front bezel, but haven't figured out how they accomplish that task. Also, does the seal go around both the lens and reflector, holding them together as an assembly? Any guidance or links to an exploded view? Thanks!! |
rhodyguy |
Mar 21 2005, 08:42 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
so you're adding a set of light searly lights? the nut on the body is a captured nut, it sort of floats with a bracket of some sort on the back side. guys retro fitting the early style lights have to adapt and drill.
k Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 09:19 AM |
