crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
I pulled my motor and went to work on the oil leaks.....
First pulled the trans and addressed the rear seal...It was only flush. Tapped it in until tight. ok that was no problem. Now to address the weeping from a galley plug that I installed...pulled it out, re-sealed it with high temp pipe seal. so far so good.. Now to the oil pump...flatteded the case, got a good seal and re-installed....all right looking good! pulled the plugs and found my jumper cables. Time to spin it up..I grab my compression gage just for grins... 1&2 150# ok not bad.. #4 is 50 # WTF???? #3 is 150#???? hmmmm. The plugs from 1&2 were wet and dark, from 3&4 light and tan?? Ok my linkage is off I can see that. But what about the pressure??? Time to take a break. go and get all the cables and battery out again...I know, I will look at the valves...oh yes this is the rocker assembly that I had a problem with...yep, valves are tight...loosen and re-perform pressure check....whew...up to around 150#..I was only running on 3 cylinders!!! and my linkage was way bad.....!! When I get this sorted out this will be one bad running car..!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) as it was this is a rocket with plenty of torque....it just lights up the tires in 1st and 2nd....time for (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) So what did you do?? |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,005 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
barely 914 related:
I attended a 2 day liscensing school for the local vintage racing sanctioning body. Of course the 914 that I intend to race is not running yet, so I had to go to school in my ford focus. raised a few eyebrows that a ford focus could give some of those cars a run. passed the school anyways |
Lo-Fi Version | Time is now: 1st July 2025 - 06:53 AM |
