> What did you do this weekend????, Only 914 work of course....
crash914
post Mar 21 2005, 06:36 AM
its a mystery to me
I pulled my motor and went to work on the oil leaks.....
First pulled the trans and addressed the rear seal...It was only flush. Tapped it in until tight. ok that was no problem.
Now to address the weeping from a galley plug that I installed...pulled it out, re-sealed it with high temp pipe seal. so far so good..
Now to the oil pump...flatteded the case, got a good seal and re-installed....all right looking good!
pulled the plugs and found my jumper cables. Time to spin it up..I grab my compression gage just for grins...
1&2 150# ok not bad.. #4 is 50 # WTF???? #3 is 150#????
hmmmm. The plugs from 1&2 were wet and dark, from 3&4 light and tan?? Ok my linkage is off I can see that. But what about the pressure???
Time to take a break. go and get all the cables and battery out again...I know, I will look at the valves...oh yes this is the rocker assembly that I had a problem with...yep, valves are tight...loosen and re-perform pressure check....whew...up to around 150#..I was only running on 3 cylinders!!! and my linkage was way bad.....!!
When I get this sorted out this will be one bad running car..!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
as it was this is a rocket with plenty of torque....it just lights up the tires in 1st and 2nd....time for (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
So what did you do??
Series9
post Mar 21 2005, 01:45 PM
Lesbians taste like chicken.
And:
crash914   What did you do this weekend????   Mar 21 2005, 06:36 AM
skline   That is good news about your engine. My first gues...   Mar 21 2005, 06:59 AM
Joe Ricard   Drove the living piss out of it. Attended an Autoc...   Mar 21 2005, 07:01 AM
scottb   pulled the car out of the storage garage into prim...   Mar 21 2005, 07:09 AM
d914   also drove the Piss outta it for half the weekend ...   Mar 21 2005, 07:19 AM
michel richard   Some P-content work: Started my Lotus Europa on t...   Mar 21 2005, 07:19 AM
rick 918-S   Made this for Larry. http://www.9...   Mar 21 2005, 07:25 AM
CptTripps   I finished up all the paint removal, Replaced the ...   Mar 21 2005, 08:03 AM
Lawrence   ...   Mar 21 2005, 08:07 AM
Gint   Nothing. OK, I did look at some pictures of my be...   Mar 21 2005, 08:09 AM
Tom73   Installed a new dash pad..... http...   Mar 21 2005, 08:12 AM
Joe Sharp   Got some new wheels for Beauty, and I was tinkerin...   Mar 21 2005, 08:12 AM
vsg914   All I did to my car was wash and drive, but, I did...   Mar 21 2005, 08:14 AM
Joe Sharp   Oh yeah! Imade a bracket for the LM-1n and put...   Mar 21 2005, 08:40 AM
Joe Sharp   The LM-1 on the dash. http://www.9...   Mar 21 2005, 08:41 AM
Joe Sharp   The Bracket. http://www.914world.c...   Mar 21 2005, 08:43 AM
Bleyseng   hehe, someone installed the MPS cover 90 degrees o...   Mar 21 2005, 08:58 AM
tat2dphreak   well, I took off all last week, we went out of tow...   Mar 21 2005, 09:13 AM
brant   barely 914 related: I attended a 2 day liscensing...   Mar 21 2005, 09:19 AM
trekkor   First a/x with LPR PCA. 3 seconds off top time. M...   Mar 21 2005, 09:20 AM
Brando   Saturday I was at the Festival of Speed helping ou...   Mar 21 2005, 10:02 AM
Mueller   worked on my big brake kit for the front on my 914...   Mar 21 2005, 10:07 AM
siverson   Friday night I installed a new Dansk steel muffler...   Mar 21 2005, 10:12 AM
bondo   I made some attempts at anodizing the LT1 intake m...   Mar 21 2005, 10:53 AM
MarkG   Fixed both door locks, lubricated internal door lo...   Mar 21 2005, 11:01 AM
Rhodes71/914   Installed a banged up front valance. I did paint i...   Mar 21 2005, 11:20 AM
dinomium   Drank some of Shane's (red914) birthday Whiske...   Mar 21 2005, 11:30 AM
DNHunt   Volunteered as a "course engineer" at the local PC...   Mar 21 2005, 11:51 AM
Root_Werks   Not much, wife and I took her new car on a small t...   Mar 21 2005, 12:33 PM
azbill   Gave the engine a bath installed new ignition wire...   Mar 21 2005, 12:49 PM
Joe Sharp   I forgot that I had a window put in yesterday. Now...   Mar 21 2005, 01:04 PM
SirAndy     Mar 21 2005, 01:36 PM
Series9   Performed some much-needed garage improvement. I ...   Mar 21 2005, 01:45 PM
Series9   And:   Mar 21 2005, 01:45 PM
Brando   CAMP 914 is actually the garage of your house? Dam...   Mar 21 2005, 04:39 PM
- Lo-Fi Version Time is now: 1st July 2025 - 08:08 AM
