So I pulled my dizzy |
wrpspddrvr |
Mar 22 2005, 08:19 AM
Member Group: Members Posts: 333 Joined: 22-December 04 Member No.: 3,317 Region Association: None |
Okay. So I'm still trying to install this *%$#^&)(@)_!&$%)&@#*%$#& Crane XR700.
I got it all installed yesterday and tried to turn the engine over, but it didn't work. The starter is working okay, but the engine wasn't catching. Every now and then, though, it sounded like it was trying to, but just couldn't. It would make a quick spitting noise. That's the only way I can explain it. Like it was trying to catch, but couldn't. I conculted my mechanic friend upstairs, and we both decided it was probably timing. So here's the thing: I had pulled out my distributor to ease the installation of the device. I know I turned the rotor shaft a few times. When I tried to put the dizzy back in, it wouldn't go in with the rotor turned towards the mark on the dizzy. The rotor is turned a 1/4 turn away (clockwise) from the #1 cyl mark when the two pegs slot into place when I re-install the diz. WTF am I doing wrong? I know there's something.......... Should I jack up one side of the car and turn a drive wheel until it lines up? On top of that, I don't think the LED is lighting up at all. I tried aligning the slots to the light, but the f'ing light never lit up. Tried having a roommate crank the engine while I watched the diz- no light. ?????!!!!!??????!!!!?!?!?!?!?!?!?! I've got about 9 hours in this damn thing. The three nicest days of my spring break have been wasted trying to install this "60 minute easy installation" POS, when I could have been zooming around with my top off. I'm damn tempted to go back to points, but I figure it'll be just as much a PITA to go back to that as it would to continue this install. I figure I'm about 90% done. The actual install of the unit itself is all done, now I just have to get it to interface with my car. Any help would be MUCHO appreciated! Thanks, Cole (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
ArtechnikA |
Mar 22 2005, 08:26 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
the alignment of the rotor shaft isn't significant. put the body in the way it's supposed to go. the drive shaft (for the distributor) has an OFFSET slot. (have a look at it with a good flashlight.) just make sure the offset parts align right. it sounds to me as if you had it installed 180 out. but yes, you WILL need to make a significant timing adjustment because the slot in the shutter wheel is not the same place the points opened before. the LED is an INFRARED LED. it DOES NOT light up in the visible part of the spectrum; you'll never see it light up. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:09 AM |
