> Tangerine Racing in the house!, Chris arrived at 1Am.....
Jake Raby
post Mar 23 2005, 09:25 AM
Engine Surgeon
The Tangerine crew pulled in to the shop at around 1Am this morning....
Chris has come down to install his new F Production RAT engine with HAm heads that are VERY insane! We are finishing up the engine today and it should be on the dyno tonight and tested tomorrow. We plan on doing some extensive testing with this engine to scrounge every bit of power it possibly has out of it. I plan on doing some carb and velocity stack swaps, venturi swaps and we are even going to do some DTM testing with it Vs Chris' modified corvair fan arrangement both for power as well as running temp comparisons.
This is actually the least developed engine that we will be building Chris as it is the "Regular Season engine". It is still a very nasty animal that will make gobs of power, but since it's a regular season engine it also has to be much more longevity filled and therfore not as many risks can be taken with its tolerances.
The "Runoffs engine" is a different story. It only has to live for two hours for one weekend of racing so it will have every trick known to man and even crazier HAM heads.
With Chris' excellent driving skills and a pair of RAT engines with Len doing things to the heads that have never been done before to this level it is our goal to get a 914 on the podium at the runoffs and thats something that hasn't happened in about 20 years!
If anyone wants to come out to Atlanta this weekend send me an email to boss@aircooledtechnology.com and I'll tell you where we are going to be so we can meet.
Thorshammer
post Mar 26 2005, 06:34 PM
As my friends would say UNNNNLUCKY. Still 186 is very good numbers.
Kevin,
As for the Venturi chnage to 38 mm with 46 mm carbs, yes it should be a contender, thats what I was hoping for. This motor makes 194 on the dyno I use. But that number was with the 34 mm venturis, and 40 mm carbs. I "borrowed" a set of 46 with 36 Venturis and thye were'nt even jettted close, and the owner woul'nt let me mess with them. But I would hope to hit 200 with this set up. At 1950 I need to make 210 to be even with the Miatas. The Hewland will be an advantage. I hope this will make a major advantage as far as shift speed goes. But we'll see.
Erik Madsen
Jake Raby   Tangerine Racing in the house!   Mar 23 2005, 09:25 AM
spunone   Looks like you'll be havin fun this weekend if...   Mar 23 2005, 09:31 AM
Jake Raby   Yep, we may need some "Stacks" made up.... Definat...   Mar 23 2005, 09:36 AM
spunone   OK then just fax me the sizes and I'll see wh...   Mar 23 2005, 09:41 AM
URY914   Jake, Chris We want updates over the weekend, qua...   Mar 23 2005, 09:47 AM
Aaron Cox   URY, you need a RAT motor in your gokart....   Mar 23 2005, 09:48 AM
URY914   <...   Mar 23 2005, 12:06 PM
Jake Raby   I stayed away from Race engines for a very long ti...   Mar 23 2005, 12:13 PM
spunone   And That is why you GOTTA LOVE RACING there aint n...   Mar 23 2005, 12:26 PM
grantsfo   As the old saying goes the BS stops when the green...   Mar 23 2005, 12:59 PM
Dave_Darling   http://www.914world.com/bbs2/...   Mar 23 2005, 06:01 PM
SpecialK   Couldn't find anything on SPEED Channel for SC...   Mar 23 2005, 08:40 PM
Jake Raby   No Speed coverage for SCCA Nationals except the Ru...   Mar 23 2005, 09:19 PM
SpecialK   http://www.914world.com/bbs2/...   Mar 25 2005, 08:33 AM
joea9146   http://www.914world.com/bbs2/h...   Mar 25 2005, 10:57 AM
synthesisdv   OK then, here is Jake at tech inspection this morn...   Mar 25 2005, 11:13 AM
Racer Chris   I won't have any pictures available until I ge...   Mar 25 2005, 12:46 PM
spunone   Good luck this weekend Jake & Chris http://www.914world.com/bbs2/html/e...   Mar 25 2005, 06:21 PM
Andyrew   ...   Mar 25 2005, 07:33 PM
guywan914   http://www.914world.com/bbs2/...   Mar 25 2005, 07:35 PM
jd74914     Mar 25 2005, 09:42 PM
Thorshammer   In my experience, comparing dyno numbers is not th...   Mar 25 2005, 11:15 PM
groot   Excellent work Jake!!! Enjoy the week...   Mar 26 2005, 09:38 AM
william harris   Go get em Chris! We want those in car picture...   Mar 26 2005, 10:24 AM
Brett W   I am by no means trying to downplay Jake's res...   Mar 26 2005, 10:54 AM
guywan914   Okay, just came in from the garage after spending ...   Mar 26 2005, 03:26 PM
John Jentz   I just got back from Road Atlanta, had to leave ea...   Mar 26 2005, 03:55 PM
URY914   They need to get some sleep before they kill thems...   Mar 26 2005, 04:09 PM
SGB   1. Crew before 1st saturday practice   Mar 26 2005, 05:44 PM
SGB   2. RAT motor with Chris's corvair based coolin...   Mar 26 2005, 05:46 PM
SGB   3. SHEE-II-___ back in two laps- whats wrong?   Mar 26 2005, 05:49 PM
Jake Raby   The lack of sleep did play into todays events.. T...   Mar 26 2005, 05:56 PM
SGB   Len holds the evil spark plug... see that channel ...   Mar 26 2005, 05:59 PM
Jake Raby   Yep... That was the first sign of an issue.. That...   Mar 26 2005, 06:08 PM
synthesisdv   Jake, I'm heading out in the morning for Moros...   Mar 26 2005, 06:43 PM
Jake Raby   Chris had just looked at the EGT right before it h...   Mar 26 2005, 07:12 PM
Joe Ricard   Well for what it is worth a problem was going to h...   Mar 26 2005, 08:08 PM
Racer Chris   First of all let me say that there was nothing wro...   Mar 26 2005, 09:56 PM
Thorshammer   Chris, Bad luck, better luck next time, Summit N...   Mar 26 2005, 10:01 PM
grantsfo   Bummer ...Maybe more reliability and less power ...   Mar 26 2005, 10:30 PM
Bleyseng   "Remember, sleep is a weapon" Jason Bourne Sounds...   Mar 26 2005, 10:40 PM
Brett W   Chris, Jake, Pete, and Len, Sorry to hear about y...   Mar 26 2005, 11:33 PM
Racer Chris   Thanks for the support guys, and special thanks to...   Mar 26 2005, 11:56 PM
redshift   http://www.914world.com/bbs2/html/e...   Mar 27 2005, 01:26 AM
redshift
- Lo-Fi Version Time is now: 14th July 2025 - 04:30 AM
