Bleeding brakes sucks!!! |
mightyohm |
Mar 30 2005, 12:24 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I spent another 1-2 hours tonight bleeding the brakes on my 914. The rears bled fine but one of the fronts (which I rebuilt) is giving me what seems like an endless stream of tiny bubbles. I haven't checked the other front yet but I am guessing it will too.
How long is this supposed to take?? Is bleeding brakes a day long job after you rebuild the calipers and put them on dry? I've been through over 2 quarts of brake fluid so far. I think just on this one caliper we pumped it about 100 times! Tiny little bubbles forever and ever. Also I noticed that the assembly lube I used is dissolving into the brake fluid, I get some blue bubbles from time to time as well. That doesn't seem right. I used the Permatex stuff in the little packets that says you can use it on caliper pistons etc etc. Anyone have a pressure bleeder I can borrow? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
kermit |
Mar 30 2005, 01:05 AM
Member Group: Members Posts: 169 Joined: 2-November 04 From: Millbrae, CA Member No.: 3,049 |
Once you get a hold of a pressure bleeder, you may want to consider putting in the brake fluid through the caliper nipple. Just do it slowly so it doesn't overflow the resevoir. This tends to push all the air bubbles out.
This is a trick that I did on my motorcycle after I rebuilt the caliper and put on new brake lines. I imagine this should work for the 914 as well. Look luck and let me know if you try this and if it works for you. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:47 PM |
