do all 76's have the rrear swaybar mounts? |
nickg |
Mar 30 2005, 07:25 PM
Senior Member Group: Members Posts: 501 Joined: 30-August 04 From: franklin, nj Member No.: 2,652 |
the plates for the bar to attach? my car did not have sways from the factory?
JeffBowlsby |
Mar 30 2005, 07:55 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Let us know what you nfind...but I would doubt it. The sway bar would have welded-on plates under the trunk and reinforcement plates inside the trunk, as well as ball end shock bottom bolts. If you have all those, then someone simply removed the bar. No weld plates means that your car did not come with sways from the factory, as it was an accessory item. They came in F+R pairs too...so if you have the rear you should have the front too...or none at all.
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:20 AM |
