Let us know what you nfind...but I would doubt it. The sway bar would have welded-on plates under the trunk and reinforcement plates inside the trunk, as well as ball end shock bottom bolts. If you have all those, then someone simply removed the bar. No weld plates means that your car did not come with sways from the factory, as it was an accessory item. They came in F+R pairs too...so if you have the rear you should have the front too...or none at all.
