do all 76's have the rrear swaybar mounts? |
nickg |
Mar 30 2005, 07:25 PM
Senior Member Group: Members Posts: 501 Joined: 30-August 04 From: franklin, nj Member No.: 2,652 |
the plates for the bar to attach? my car did not have sways from the factory?
914werke |
Mar 30 2005, 07:30 PM
"I got blisters on me fingers" Group: Members Posts: 10,029 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yes. supposedly. You might chk the build date of your chassi for a very early 76 (or 75) car.
nickg |
Mar 30 2005, 07:45 PM
i know it was built in 75(they all were) I have a complete rear bar to put in (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) . the plates should be there? cool
JeffBowlsby |
Mar 30 2005, 07:55 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Let us know what you nfind...but I would doubt it. The sway bar would have welded-on plates under the trunk and reinforcement plates inside the trunk, as well as ball end shock bottom bolts. If you have all those, then someone simply removed the bar. No weld plates means that your car did not come with sways from the factory, as it was an accessory item. They came in F+R pairs too...so if you have the rear you should have the front too...or none at all.
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Bleyseng |
Mar 30 2005, 08:05 PM
Its my understanding that only the last run of cars had all the goodies due to Dealer demands that the cars be loaded so they could sell them at a premium, even with a surchange.
Geoff |
RustyWa |
Apr 1 2005, 02:19 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
'75-'76 do not have the reinforcement plate on the inside of the trunk because of the extra reinforcement for the big bumpers. |
Lo-Fi Version | Time is now: 30th April 2024 - 08:04 AM |
