> Electrical Problems
Loser_Cruiser
post Apr 6 2005, 03:11 PM
Looking for some advice. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
I bought a 76 2.0L FI DL 914. It did not run right and most of the electrical was not working also. Well, now I have head, signal, brake, emergency, backup lights, starter and wipers. Horn and trunk light are still an issue.
I removed gas tank and flushed, good shape, replaced gas lines and fuel filter. Replaced plugs. points, condenser, rotor, cap and plug wires, new air filter, changed engine and transmission oil, and filter.
Car started right up and runs very nice. Runs very nice for about 5 minutes and then cuts out like it not getting gas or loading up.
Placed a pressure gauge on the FI today, and it stays at 30-32 psi when primed and running. When the car starts to cut out the pressure is still 30-31 psi. Vacuum lines look good and in the right place.
Car is a California car and loaded with the EGR equipment, EGR pump is removed.
Request some advice on the next hoop to jump thru.
Has good charge and battery. Cleaned fuse box today, has good conductivity on the ground strap. Good charging system and battery. Cleaned FI, good spray!!!
I am going to check the cyl pressure and valve tolerances tomorrow.
Running out of things I know what to look at. H E L P !!!!!!!!
Ian
_________________
Come rescue me!
We’ve got a line in the sky (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
TheCabinetmaker
post Apr 6 2005, 03:38 PM
I drive my car everyday
Add a valve adjust to that list too, and new gas if you haven't already.
Loser_Cruiser   Electrical Problems   Apr 6 2005, 03:11 PM
Rand   I had the same problems. Headlights came on but di...   Apr 6 2005, 03:17 PM
SGB   Many strange things happen with the battery is spu...   Apr 6 2005, 03:25 PM
merrill   Sounds like a few issues that I have encountered b...   Apr 6 2005, 03:31 PM
mihai914   Also you may want to have the injectors cleaned, a...   Apr 6 2005, 03:32 PM
vsg914   Add a valve adjust to that list too, and new gas i...   Apr 6 2005, 03:38 PM
merrill   Oh, and don't forget to change the gear oil. ...   Apr 6 2005, 03:59 PM
mihai914   What the hell, just go buy a new boxster it will c...   Apr 6 2005, 04:03 PM
Loser_Cruiser   Buying the boxster would be nice but unecessary be...   Apr 6 2005, 11:50 PM
Seaside6   Make sure the all the fuse contacts are clean. St...   Apr 6 2005, 11:56 PM
mattillac   <...   Apr 7 2005, 12:27 AM
rhodyguy   important fyi, there is a LARGE ground strap that ...   Apr 7 2005, 09:24 AM
Loser_Cruiser   I pulled the distributor today and cleaned the inj...   Apr 24 2005, 09:49 PM
BMartin914     Apr 24 2005, 10:34 PM
Jeffs9146
  Apr 25 2005, 08:56 AM
7391420   Check the fuel filter, I had a similar issue after...   Apr 25 2005, 09:35 AM
Cap'n Krusty     Apr 25 2005, 10:46 AM
Loser_Cruiser   What does the CHT stand for? and where is it?   Apr 26 2005, 11:50 PM
Loser_Cruiser   OK CHT = > Cylinder Head Temperature sensor. Will ...   Apr 29 2005, 05:20 PM
Travis Neff   I had the same problem coming back from the WCC, c...   Apr 29 2005, 05:28 PM
Loser_Cruiser   I made up a pressure guage on a tee for under ...   Apr 29 2005, 09:06 PM
Loser_Cruiser   http://www.914world.com/bbs2/html/e...   May 17 2005, 11:59 PM
airsix
- Lo-Fi Version Time is now: 12th October 2026 - 07:55 PM
