> Intermittent Wiper Relay details, Pictures from NOS unit
Qarl
post Apr 6 2005, 06:52 PM
Shriveled member
Here is the entire harness and the relay...
JeffBowlsby
post Apr 6 2005, 10:57 PM
Cool thread. I have everything I need to produce these harnesses to match the OEM. They are pretty simple but I would only use the correct color coded wires, the correct relay base (Qarl that link you posted is not the right part or at least the photo is not right), and quality wire terminals. How about that single pole box housing? Got that new too.
Hey if anyone is interested I might be persuaded to do a run of these to save costs for everyone. I would probably put together the harness/relay and instructions in 1 package to save running around.
But NOT till after the WCC...and I don't have the costs figured out yet...but it wouldn't be too bad.
Let me know if you are interested... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Qarl   Intermittent Wiper Relay details   Apr 6 2005, 06:52 PM
Aaron Cox   i can make that..... just need the relay socket......   Apr 6 2005, 06:53 PM
Qarl   Here is a close up of the relay... Here is the co...   Apr 6 2005, 06:55 PM
Qarl   Here are the end connectors...   Apr 6 2005, 06:56 PM
Qarl   Another...   Apr 6 2005, 06:56 PM
Qarl   The harness is part number 914.612.148.10 The rel...   Apr 6 2005, 06:59 PM
ewdysar   Hey, does anyone know where to get those cool push...   Apr 6 2005, 07:09 PM
Qarl   They are called piggyback connectors. I had purch...   Apr 6 2005, 07:40 PM
Aaron Cox   relays are available new.... i need to find out w...   Apr 6 2005, 07:49 PM
Qarl   With the info I gave you, you can find the harness...   Apr 6 2005, 07:55 PM
Aaron Cox     Apr 6 2005, 08:04 PM
Qarl   Because Aaron is a moron and doesn't know how ...   Apr 6 2005, 08:18 PM
Qarl   Just kidding Aaron... You DO know how to use Goog...   Apr 6 2005, 08:19 PM
Aaron Cox     Apr 6 2005, 08:22 PM
9146986   OK, so how do you get the damn thing to work? I p...   Apr 6 2005, 08:55 PM
Aaron Cox     Apr 6 2005, 09:03 PM
Qarl   And you broke the tab off on the wiper switch, rig...   Apr 6 2005, 09:09 PM
JmuRiz   So...what wires do these connect to? I'm stil...   Apr 6 2005, 09:19 PM
Qarl   I think SirAndy did one in the Classic Thread foru...   Apr 6 2005, 09:29 PM
Jeff Bowlsby   Cool thread. I have everything I need to produce ...   Apr 6 2005, 10:57 PM
brownaar   Jeff, Go for it. I think you would have plen...   Apr 7 2005, 07:10 AM
nickg   qarl, what is the part # on the block? molede in, ...   Apr 7 2005, 07:24 AM
ChrisFix     Apr 7 2005, 07:35 AM
jim_hoyland   Good Point Aaron: Many cars have upgraded the swi...   Apr 7 2005, 07:44 AM
brownaar   I know it's been suggested elsewhere you can j...   Apr 7 2005, 08:12 AM
Bleyseng   That six block is the same as the rear trunk smog ...   Apr 7 2005, 08:32 AM
McMark   I'm in Jeff. For more than one. I'd like...   Apr 7 2005, 08:44 AM
JmuRiz   I'd be in for one too!   Apr 7 2005, 08:55 AM
mack914   I three!!! http://...   Apr 7 2005, 09:14 AM
Jeff Bowlsby   There seems to be a good interest...I will plan to...   Apr 7 2005, 01:08 PM
brownaar   Another question to ponder...... This thread shows...   Apr 7 2005, 01:12 PM
Aaron Cox   yes... you need the genuine 4 position switch.......   Apr 7 2005, 01:17 PM
Rog914   brownaar, the fifth wire is buried in the harness...   Apr 7 2005, 03:49 PM
markb   Hi Jeff. Anything happening with this?   May 16 2005, 11:55 PM
jim_hoyland   Two questions: Is there a test that can be perfor...   May 17 2005, 07:35 AM
Bleyseng   Which tab do you break off on the switch?? Show a ...   May 17 2005, 08:29 AM
itsa914   Count me in for this if it could be done on a 70 9...   May 17 2005, 09:28 AM
fiid   Small hijack..... I got a programmable later VW re...   May 17 2005, 10:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:43 AM
