Qarl
Apr 6 2005, 06:52 PM
Here is the entire harness and the relay...
Aaron Cox
Apr 6 2005, 06:53 PM
i can make that..... just need the relay socket..... and a relay... what does it plug into?
have a schematic?
Qarl
Apr 6 2005, 06:55 PM
Here is a close up of the relay...
Here is the connection order starting at the top and going clockwise.
I am looking at the bottom of the relay where the pins are...
Pin 15 (top) goes to red
Pin S (3 o'clock) is not connected
Pin 53N (6 o'clock) goes to blue/black
Pin 31 (9 o'clock) goes to brown
The center pin 53S goes to white.
Qarl
Apr 6 2005, 06:56 PM
Here are the end connectors...
Qarl
Another...
Qarl
Apr 6 2005, 06:59 PM
The harness is part number 914.612.148.10
The relay receptical on the harness has the following part number on it 3 334 485 008
The relay is shown below...
ewdysar
Apr 6 2005, 07:09 PM
Hey, does anyone know where to get those cool push-on connectors with the built in jumper tab? I'd rather use those than cramming two wires into one connector.
Eric
Qarl
Apr 6 2005, 07:40 PM
They are called piggyback connectors.
I had purchased some a while back when making the resistor packs for the LEDs
Aaron Cox
Apr 6 2005, 07:49 PM
relays are available new....
i need to find out where i can buy the harness....
were they installed on a VW of some sort?
Qarl
Apr 6 2005, 07:55 PM
With the info I gave you, you can find the harness (or one close to it) for only 0.75. All you need to do is add the connectors.
I know where you can get the relays for $10.00
Hint: Google in the part numbers I gave you.
Aaron Cox
Apr 6 2005, 08:04 PM
QUOTE (Qarl @ Apr 6 2005, 06:55 PM) |
Hint: Google in the part numbers I gave you. |
you rock karl....
Qarl
Apr 6 2005, 08:18 PM
Because Aaron is a moron and doesn't know how to use Google...
Relays listed here...
http://www.flatsixonline.com/477.htm(I assume they are available if they are listed).
Harness...
http://www.tessco.com/products/displaySkus...9&subgroupId=63Just scroll down until you see the part number. The harness is just the socket, but I "think" the one a that top of the grouping that beins with the 6 is the same socket with wires already installed. All you would need to do is add the terminals and you're done!
Qarl
Apr 6 2005, 08:19 PM
Just kidding Aaron...
You DO know how to use Google, I'm sure.
Aaron Cox
Apr 6 2005, 08:22 PM
QUOTE (Qarl @ Apr 6 2005, 07:18 PM) |
Because Aaron is a moron and doesn't know how to use Google... |
thanks qarl....i guess....
IronHillRestorations
Apr 6 2005, 08:55 PM
OK, so how do you get the damn thing to work?
I put one on a customer's car and we got: high, low, intermittent, but at the off position it was still intermittent.
Unplug the relay and it would work on high, low, and off, but not park by itself.
We changed out three relays, one of which I know was good, and it didn't make any difference.
Ideas???
Aaron Cox
Apr 6 2005, 09:03 PM
QUOTE (9146986 @ Apr 6 2005, 07:55 PM) |
Ideas??? |
wired wrong? switch is f-ed?
Qarl
Apr 6 2005, 09:09 PM
And you broke the tab off on the wiper switch, right?
Also, I understand that the relay pictures is for 1973-1976,
I believe there is a different relay for the 1970 to 1972 cars.
JmuRiz
Apr 6 2005, 09:19 PM
So...what wires do these connect to? I'm still lost
Maybe once you get it all connecte and working a writeup is in order, it'd be great to have intermittent wipers.
Qarl
Apr 6 2005, 09:29 PM
JeffBowlsby
Apr 6 2005, 10:57 PM
Cool thread. I have everything I need to produce these harnesses to match the OEM. They are pretty simple but I would only use the correct color coded wires, the correct relay base (Qarl that link you posted is not the right part or at least the photo is not right), and quality wire terminals. How about that single pole box housing? Got that new too.
Hey if anyone is interested I might be persuaded to do a run of these to save costs for everyone. I would probably put together the harness/relay and instructions in 1 package to save running around.
But NOT till after the WCC...and I don't have the costs figured out yet...but it wouldn't be too bad.
Let me know if you are interested...
brownaar
Apr 7 2005, 07:10 AM
Jeff,
Go for it. I think you would have plenty of takers, myself included.
I have a question while we're at it. For anyone that has upgraded to an electric washer pump with a newer wiper switch.......does the newer switch have the same ability to set up for intermittent wipe? I'd like to do both, the electric pump and the intermittent setup.
Aaron
nickg
Apr 7 2005, 07:24 AM
qarl, what is the part # on the block? molede in, i can make the harness but the makes it look factory
ChrisFix
Apr 7 2005, 07:35 AM
QUOTE (bowlsby @ Apr 6 2005, 08:57 PM) |
Let me know if you are interested... |
Sign me up, I'll take one! If you really think you might make this, please put me on your list for when they're completed. I want one....
jim_hoyland
Apr 7 2005, 07:44 AM
Good Point Aaron:
Many cars have upgraded the switches to handle the elecric washers.
Anyone know whether the intermittent relay set up will be compatible ??
I believe my car has a 924 or jetta wiper switch...definately not the original.
brownaar
Apr 7 2005, 08:12 AM
I know it's been suggested elsewhere you can just run the electric washer pump off the intermittent cycle, but that seems to be a suboptimal solution at best.
Aaron
Bleyseng
Apr 7 2005, 08:32 AM
That six block is the same as the rear trunk smog relay on the 75-76 cars. Look in the trunk under the latch for 'em.
Yep, I would be interested in the wiring harness as I have the other parts laying around.
Which tab do you break off in the wiper switch?? Show a pic of this please. (this is why you get high,low, intermittant and still on). The real intermittant switches are high, low, inter and off, four settings switches.
Geoff
McMark
Apr 7 2005, 08:44 AM
I'm in Jeff. For more than one. I'd like to have a few extras for customer cars. I'll be sending the KitCarlson harness after WCC. So get ready.
JmuRiz
Apr 7 2005, 08:55 AM
I'd be in for one too!
mack914
Apr 7 2005, 09:14 AM
I three!!!
JeffBowlsby
Apr 7 2005, 01:08 PM
There seems to be a good interest...I will plan to make up an initial run of ten or so after the WCC. Will post again when they are ready to ship.
brownaar
Apr 7 2005, 01:12 PM
Another question to ponder......
This thread shows a 4-wire harness, but the Classic thread
Wiper Relay Instructionstalks of a 5-wire harness. What is correct?
Aaron
Aaron Cox
Apr 7 2005, 01:17 PM
yes...
you need the genuine 4 position switch....
high low intermittent and off
Rog914
Apr 7 2005, 03:49 PM
brownaar,
the fifth wire is buried in the harness close to where you place the relay plug. I beleive it a brown wire I think. If you look at the harness (on 73 to 76) around where the wiper motor wires are and follow them back toward the outside of the car you should see a wire looped back. Follow & feel the harness for a small hump. That's where the "fifth" terminal will be. You'll have to unwarp or very carefully cut the harness to get it. When you get it out it will snap into the empty spot on the relay plug.
It can be a pain trying to find it, just take your time.
Ralph
74 2.0
markb
May 16 2005, 11:55 PM
Hi Jeff. Anything happening with this?
jim_hoyland
May 17 2005, 07:35 AM
Two questions:
Is there a test that can be performed with a voltmeter on the relay's wiring that would verify everything will be hunky-dory and avoid the problem described above.
And, I had a Jetta wiper switch installed when I converted to electric washer pump. Can the relay/harness still be used ?
Bleyseng
May 17 2005, 08:29 AM
Which tab do you break off on the switch?? Show a pic.
GaroldShaffer
May 17 2005, 09:28 AM
Count me in for this if it could be done on a 70 914?
fiid
May 17 2005, 10:34 AM
Small hijack..... I got a programmable later VW relay. It has an extra pin on it marked "I". I bent that pin to the side and plugged it in (it fits in the harness socket). So now my wipers auto-park, and they do the "3 wipes on wash" thing - both are functions that didn't work before. But I have no intermittent. I have a 924 washer stalk as well - and I had to do some mods to get that to fit in the 914 IIRC.
Anyone seen this type of relay before - or know what my dealio is?
TIA.
