Intermittent Wiper Relay details, Pictures from NOS unit |
Qarl |
Apr 6 2005, 06:52 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Here is the entire harness and the relay...
Aaron Cox |
Apr 6 2005, 06:53 PM
i can make that..... just need the relay socket..... and a relay... what does it plug into?
have a schematic? |
Qarl |
Apr 6 2005, 06:55 PM
Here is a close up of the relay...
Here is the connection order starting at the top and going clockwise. I am looking at the bottom of the relay where the pins are... Pin 15 (top) goes to red Pin S (3 o'clock) is not connected Pin 53N (6 o'clock) goes to blue/black Pin 31 (9 o'clock) goes to brown The center pin 53S goes to white. Attached image(s) |
Qarl |
Apr 6 2005, 06:56 PM
Here are the end connectors...
Qarl |
Another...
Qarl |
Apr 6 2005, 06:59 PM
The harness is part number 914.612.148.10
The relay receptical on the harness has the following part number on it 3 334 485 008 The relay is shown below... Attached image(s) |
ewdysar |
Apr 6 2005, 07:09 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Hey, does anyone know where to get those cool push-on connectors with the built in jumper tab? I'd rather use those than cramming two wires into one connector. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Eric |
Qarl |
Apr 6 2005, 07:40 PM
They are called piggyback connectors.
I had purchased some a while back when making the resistor packs for the LEDs |
Aaron Cox |
Apr 6 2005, 07:49 PM
relays are available new....
i need to find out where i can buy the harness.... were they installed on a VW of some sort? |
Qarl |
Apr 6 2005, 07:55 PM
With the info I gave you, you can find the harness (or one close to it) for only 0.75. All you need to do is add the connectors.
I know where you can get the relays for $10.00 Hint: Google in the part numbers I gave you. |
Aaron Cox |
Apr 6 2005, 08:04 PM
you rock karl.... |
Qarl |
Apr 6 2005, 08:18 PM
Because Aaron is a moron and doesn't know how to use Google...
Relays listed here... http://www.flatsixonline.com/477.htm (I assume they are available if they are listed). Harness... http://www.tessco.com/products/displaySkus...9&subgroupId=63 Just scroll down until you see the part number. The harness is just the socket, but I "think" the one a that top of the grouping that beins with the 6 is the same socket with wires already installed. All you would need to do is add the terminals and you're done! |
Qarl |
Apr 6 2005, 08:19 PM
Just kidding Aaron...
You DO know how to use Google, I'm sure. |
Aaron Cox |
Apr 6 2005, 08:22 PM
thanks qarl....i guess.... (IMG:http://www.914world.com/bbs2/html/emoticons/sad2.gif) |
IronHillRestorations |
Apr 6 2005, 08:55 PM
OK, so how do you get the damn thing to work?
I put one on a customer's car and we got: high, low, intermittent, but at the off position it was still intermittent. Unplug the relay and it would work on high, low, and off, but not park by itself. We changed out three relays, one of which I know was good, and it didn't make any difference. Ideas??? |
Aaron Cox |
Apr 6 2005, 09:03 PM
wired wrong? switch is f-ed? |
Qarl |
Apr 6 2005, 09:09 PM
And you broke the tab off on the wiper switch, right?
Also, I understand that the relay pictures is for 1973-1976, I believe there is a different relay for the 1970 to 1972 cars. |
JmuRiz |
Apr 6 2005, 09:19 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
So...what wires do these connect to? I'm still lost (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Maybe once you get it all connecte and working a writeup is in order, it'd be great to have intermittent wipers. |
Qarl |
Apr 6 2005, 09:29 PM
I think SirAndy did one in the Classic Thread forum...
http://www.914world.com/bbs2/index.php?act=...t=ST&f=5&t=2094 |
JeffBowlsby |
Apr 6 2005, 10:57 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Cool thread. I have everything I need to produce these harnesses to match the OEM. They are pretty simple but I would only use the correct color coded wires, the correct relay base (Qarl that link you posted is not the right part or at least the photo is not right), and quality wire terminals. How about that single pole box housing? Got that new too.
Hey if anyone is interested I might be persuaded to do a run of these to save costs for everyone. I would probably put together the harness/relay and instructions in 1 package to save running around. But NOT till after the WCC...and I don't have the costs figured out yet...but it wouldn't be too bad. Let me know if you are interested... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:14 PM |
