| Loser_Cruiser |
Apr 6 2005, 03:11 PM
Member ![]() ![]() Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest |
Looking for some advice. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
I bought a 76 2.0L FI DL 914. It did not run right and most of the electrical was not working also. Well, now I have head, signal, brake, emergency, backup lights, starter and wipers. Horn and trunk light are still an issue. I removed gas tank and flushed, good shape, replaced gas lines and fuel filter. Replaced plugs. points, condenser, rotor, cap and plug wires, new air filter, changed engine and transmission oil, and filter. Car started right up and runs very nice. Runs very nice for about 5 minutes and then cuts out like it not getting gas or loading up. Placed a pressure gauge on the FI today, and it stays at 30-32 psi when primed and running. When the car starts to cut out the pressure is still 30-31 psi. Vacuum lines look good and in the right place. Car is a California car and loaded with the EGR equipment, EGR pump is removed. Request some advice on the next hoop to jump thru. Has good charge and battery. Cleaned fuse box today, has good conductivity on the ground strap. Good charging system and battery. Cleaned FI, good spray!!! I am going to check the cyl pressure and valve tolerances tomorrow. Running out of things I know what to look at. H E L P !!!!!!!! Ian _________________ Come rescue me! We’ve got a line in the sky (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
| Seaside6 |
Apr 6 2005, 11:56 PM
Member ![]() ![]() Group: Members Posts: 51 Joined: 29-December 03 From: Seaside, CA Member No.: 1,475 Region Association: Northern California
Make sure the all the fuse contacts are clean. Strange things happen when corrosion sets in. I was sure I needed a new wiring harness. Got some contact cleaner and white grease and life is again good.
Loser_Cruiser Electrical Problems Apr 6 2005, 03:11 PM
Rand I had the same problems. Headlights came on but di... Apr 6 2005, 03:17 PM
SGB Many strange things happen with the battery is spu... Apr 6 2005, 03:25 PM
merrill Sounds like a few issues that I have encountered b... Apr 6 2005, 03:31 PM
mihai914 Also you may want to have the injectors cleaned, a... Apr 6 2005, 03:32 PM
vsg914 Add a valve adjust to that list too, and new gas i... Apr 6 2005, 03:38 PM
merrill Oh, and don't forget to change the gear oil. ... Apr 6 2005, 03:59 PM
mihai914 What the hell, just go buy a new boxster it will c... Apr 6 2005, 04:03 PM
Loser_Cruiser Buying the boxster would be nice but unecessary be... Apr 6 2005, 11:50 PM
mattillac <... Apr 7 2005, 12:27 AM
rhodyguy important fyi, there is a LARGE ground strap that ... Apr 7 2005, 09:24 AM
Loser_Cruiser I pulled the distributor today and cleaned the inj... Apr 24 2005, 09:49 PM
BMartin914 ![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 07:53 PM |
