| Qarl |
Apr 6 2005, 06:52 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Here is the entire harness and the relay...
| brownaar |
Apr 7 2005, 08:12 AM
Member ![]() ![]() Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
I know it's been suggested elsewhere you can just run the electric washer pump off the intermittent cycle, but that seems to be a suboptimal solution at best.
Aaron |
Qarl Intermittent Wiper Relay details Apr 6 2005, 06:52 PM
Aaron Cox i can make that..... just need the relay socket...... Apr 6 2005, 06:53 PM
Qarl Here is a close up of the relay...
Here is the co... Apr 6 2005, 06:55 PM
Qarl Here are the end connectors... Apr 6 2005, 06:56 PM
Qarl Another... Apr 6 2005, 06:56 PM
Qarl The harness is part number 914.612.148.10
The rel... Apr 6 2005, 06:59 PM
ewdysar Hey, does anyone know where to get those cool push... Apr 6 2005, 07:09 PM
Qarl They are called piggyback connectors.
I had purch... Apr 6 2005, 07:40 PM
Aaron Cox relays are available new....
i need to find out w... Apr 6 2005, 07:49 PM
Qarl With the info I gave you, you can find the harness... Apr 6 2005, 07:55 PM
Aaron Cox Apr 6 2005, 08:04 PM
Qarl Because Aaron is a moron and doesn't know how ... Apr 6 2005, 08:18 PM
Qarl Just kidding Aaron...
You DO know how to use Goog... Apr 6 2005, 08:19 PM
Aaron Cox Apr 6 2005, 08:22 PM
9146986 OK, so how do you get the damn thing to work?
I p... Apr 6 2005, 08:55 PM
Aaron Cox Apr 6 2005, 09:03 PM
Qarl And you broke the tab off on the wiper switch, rig... Apr 6 2005, 09:09 PM
JmuRiz So...what wires do these connect to? I'm stil... Apr 6 2005, 09:19 PM
Qarl I think SirAndy did one in the Classic Thread foru... Apr 6 2005, 09:29 PM
Jeff Bowlsby Cool thread. I have everything I need to produce ... Apr 6 2005, 10:57 PM
brownaar Jeff,
Go for it. I think you would have plen... Apr 7 2005, 07:10 AM
nickg qarl, what is the part # on the block? molede in, ... Apr 7 2005, 07:24 AM
ChrisFix Apr 7 2005, 07:35 AM
jim_hoyland Good Point Aaron:
Many cars have upgraded the swi... Apr 7 2005, 07:44 AM
Bleyseng That six block is the same as the rear trunk smog ... Apr 7 2005, 08:32 AM
McMark I'm in Jeff. For more than one. I'd like... Apr 7 2005, 08:44 AM
JmuRiz I'd be in for one too! Apr 7 2005, 08:55 AM
mack914 I three!!! http://... Apr 7 2005, 09:14 AM
Jeff Bowlsby There seems to be a good interest...I will plan to... Apr 7 2005, 01:08 PM
brownaar Another question to ponder......
This thread shows... Apr 7 2005, 01:12 PM
Aaron Cox yes...
you need the genuine 4 position switch....... Apr 7 2005, 01:17 PM
Rog914 brownaar,
the fifth wire is buried in the harness... Apr 7 2005, 03:49 PM
markb Hi Jeff. Anything happening with this? May 16 2005, 11:55 PM
jim_hoyland Two questions:
Is there a test that can be perfor... May 17 2005, 07:35 AM
Bleyseng Which tab do you break off on the switch?? Show a ... May 17 2005, 08:29 AM
itsa914 Count me in for this if it could be done on a 70 9... May 17 2005, 09:28 AM
fiid Small hijack..... I got a programmable later VW re... May 17 2005, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:42 AM |
