tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
it's not much, and it's mostly surface rust on the long, the jack post brace is worse... but the long is solid...
I'm thinking: grind/brush off all the rust and then ospho(or metal ready) and por-15 is that good enough for solid metal? or should I put a plate over it after that as an extra brace? let me know what you think... btw, when I took the rocker off, no less than a pound of DIRT fell out!! I know to clean this spot, but evidently the last guy forgot (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s) ![]() |
tat2dphreak |
ok, I got the other rocker panel off today(I had trouble getting it off, 2 of the screws were rusted tight!)...
anyway, the pics above were from the drivers side, and not bad at all... today we got to see what was below the pass. side, and I was not happy about what I saw... the other jack post is worse than the drivers side, and one small hole(small hillips screwdriver size) could be poked into the long... also, at the FRONT of long, there is(was) a plate... similar to what is under the jack post... that spot was the worst... the ENTIRE area was full of dirt, and thus very rusted, and in this area, I have a hole I can stick a finger in... pics will follow... soon |
Lo-Fi Version | Time is now: 17th June 2024 - 12:09 PM |
