Guess my cam!, Any suggestions. |
toecutter |
Apr 15 2005, 11:54 AM
Kid Close Enough Group: Members Posts: 37 Joined: 6-March 05 From: Sherman, Texas Member No.: 3,723 |
Is there any way to figure out what kind of cam the PO installed without splitting the case? The reason I ask is since I need to clean/rebuild the carbs I want to make sure they are set up for the cam. Is there a trick or am I SOL? FYI this is a 2.0 with what I am told are 1.7 heads. The carbs are Weber 40 IDF's (not 44's). I have a Compufire and SS heat exchangers. It was running like a spotted ape until recently because of grunge getting into the carbs. The fuel filters looked like they had a little poop in them. I digress. I believe the PO bought the webers and put them on right out of the box. Just looking for some advice (as always).
Aaron Cox |
Apr 15 2005, 12:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i agree....
you can see (within a relatively close range) what your lift is by measuring lift at the rocker. how much did the pushrod move? like the above mentioned.... if you had a degreed pulley you could check your duration.... match the numbers up to web/elgin/eagle/isky cam specs and you can take an eductaed guess..... |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:00 AM |
