Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
now that my 3.2 conversion is up and running I have a few bugs to work out, and i'm hoping to gain some knowledge from others that have been there done that.
My car is a 74 that previously had a 2.7 and now has a 3.2 with a KEP stage two clutch PP set up, stock DME 3.2 , and Rich Johnson mount. My questions are: 1. How is your airfilter routed with pics please. My AFM is in it's semi orig location and my current cone filter is just barely hitting the lid. I have a smaller diameter cone on order, but wanted to see what others have done. 2. I was told, that my Pilot bearing on the tranny seems to be turning all the time. My engagement is closer to the floor than i'm used to but even with a small spacer on the clutch cable end, i'm still at the end of thread for the adjusting nuts. Is a bigger spacer the answer or am i missing something specific to the kennedy set up that I should do. hopefully this made sense, I have pics on my home computer i can post later. TIA Ferg. |
Ferg |
Thanks, you're right, new 915 flywheel. I'll find out what exactly was done during the install and report back, I'm sure the the groove was not removed, and i'm using a regular TO bearing.
GREAT INFO (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Ferg PS, It's a crank up new rebuild, so i'm putting on the first 1k without going over 4k rpm's... (engine came with warrenty so i'm following specific break in procedure) I can't wait to uncork this SOB (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Lo-Fi Version | Time is now: 11th July 2025 - 03:43 PM |
