Removing stub axle from hub, Tips and tricks welcome |
RustyWa |
Apr 21 2005, 11:20 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
So I got the 30mm nuts removed from my stub axles. The half shaft on the passenger side came out of the hub easy as cake but, the drivers side will not budge. I've beat the hell out of it with a 3 lb. hammer and brass drift, soaked it with PB blaster, put the nut on backwards and beat on it. Nothing has worked. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I would like to get it out without destroying the bearing.
I've got an air hammer with a pointed chisel I've been thinking about trying, by placing in the hole in the center of the stub axle. I'm afraid it might mushroom out the stub axle. Any suggestions? I need some moral support. |
URY914 |
Apr 22 2005, 11:11 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,967 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Pull like crazy on the axle from the inside. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
OK, maybe not. Bigger BFH will work. Paul |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:20 AM |
