> Battery re-location ??? HELP !!, V8 project car - tight spot
ajracer
post Apr 24 2005, 06:42 PM
Just thought I might get some good comments or suggestions in mounting my Optium
Battery within the engine bay of my V8 project car. You will notice from the attached
photos the vehicle has a roll bar which passes through the original battery location as
well over top my "new" suggested location.
Does anyone have any pictures of their V8 project car showing if there is sufficent room
around this area; which may be needed to remove the battery for replacement. Can I
actually remove it once the V8 is installed. Since I am a little while from installing the
engine just wanted to know if anyone has previously used this location or the original
location successfully ? I understand the Optium battery can be mounted just about
anywhere and seeing that I am trying to retain some luggage storage space I thought
this might work ok.
Any comments, replies or suggestions are appreciated. Thanks from Toronto
Allan
neo914-6
post Apr 25 2005, 09:19 PM
neo life
QUOTE (ClayPerrine @ Apr 24 2005, 05:08 PM)
Put a battery box in the rear trunk that drops down to the right of the transmission. Make a cover for it so that you can still use the trunk.
Just my .02
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Jaide used this location in the 80's.
ajracer   Battery re-location ??? HELP !!   Apr 24 2005, 06:42 PM
ajracer   Top view   Apr 24 2005, 06:42 PM
ajracer   Another view   Apr 24 2005, 06:43 PM
dlee1967   Allan, why don't you just move it to the front...   Apr 24 2005, 06:59 PM
ClayPerrine   Put a battery box in the rear trunk that drops dow...   Apr 24 2005, 07:08 PM
JB 914   I would put it in the front or rear trunk. I thin...   Apr 24 2005, 11:04 PM
ajracer   Bump Anyone else with some thoughts or suggestion...   Apr 25 2005, 09:12 PM
neo914-6     Apr 29 2005, 07:15 PM
Brad Roberts   Flip the battery over on its side facing us in the...   Apr 29 2005, 07:23 PM
ajracer   Brad: Thanks for the simple yet great idea; I tri...   May 2 2005, 08:47 PM
Brad Roberts   I was gifted with *some* common sense.
- Lo-Fi Version Time is now: 15th April 2026 - 12:07 AM
