> HOUSTON, WE HAVE A PROBLEM!!!!!
ne14914
post Jun 27 2003, 09:54 PM
Me N My914
OK - I tried to change the oil pressure switch - hoping this would rid me of my oil leak problem, and while installing the new one, I dropped/lost in in the tin (IMG:style_emoticons/default/headbang.gif)
While looking inside, where the switch goes, I could see the oil, and it looked as if it was being syphoned - you know like gulp, gulp - and the gulps were in sync with the drips coming from up underneath the car.
So - I have two problems / questions:
1. Do you think a magnent will pull the switch out? Its not visible (IMG:style_emoticons/default/splat.gif) and if not - is it difficult to remove the tin? If not, how do I go about it? I took out the flat head screws, but the tin didnt move.
2. If it is not the switch - (it looks like its coming from the cooler - I hope not - but if it is, can anyone guide me through removing the cooler without dropping the engine? - And is there anything else I should check before I assume its the cooler?
Thanks - ALL help is appreciated
Malmz
post Jun 27 2003, 11:54 PM
CSOBOSC founding member
About 1 hour today, and that was w/o factory heat exchangers and lower tin since it has headers and a Dynomax muffler, and I've done my share of dropping motors. I didn't break out the air tools.
FWIW, it's much easier to just cut the back of the car off out of the way! (no, not today...)
- Lo-Fi Version Time is now: 3rd July 2025 - 12:30 PM
