| Series9 |
Apr 27 2005, 11:23 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Rick just called. He's 30 miles west of Albuquerque and his water pump is failing. He has water and is going to try to get her here, but Nico and I are on stand by with the Burb and a strong rope.
I guess he'll be a house guest for a couple of days. Any one have a 928 water pump you can overnight? |
| Joe Ricard |
Apr 28 2005, 10:29 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Unfortunately this is not an easy job for a 928 motor. the timing belt is the driver for the water pump and oil pump and of course both cams
27 bolts that just hold the pump to the block. Not to mention the brittle plastic covers and other crap that has to come off. Tensioning the belt is critical. too much tension and the pump seals will go out quickly. to loose and you can jump a tooth on a cam. Porsche has a 300 dollar tool to adjust belt tension . I only did this job once and did it by tightening the belt till it could be just twisted 90 degrees (between the tensioner and the passenger side cam gear. 500 miles it should be checked and re adjusted for a new belt. 1000 bucks at the dealer. |
Series9 The Alien is failing! Apr 27 2005, 11:23 PM
Jenny Sucks! It's a good thing he's got club... Apr 27 2005, 11:25 PM
Aaron Cox have devek overnight a pump. i hear they are the 9... Apr 27 2005, 11:28 PM
ThinAir914 Bummer! When I saw him this afternoon he was ... Apr 27 2005, 11:34 PM
Series9 Apr 28 2005, 12:47 AM
rick 918-S The pump was a reman. I installed it late last sum... Apr 28 2005, 01:28 AM
ablose58 good luck rick http://www.914... Apr 28 2005, 03:32 AM
MJHanna Call Russ Kelso. He might have one laying around. Apr 28 2005, 05:45 AM
jim912928 If devek doesn't have one (unlikely)...you can... Apr 28 2005, 06:45 AM
CptTripps You are right...it couldn't have happened in a... Apr 28 2005, 07:09 AM
spare time toys Rick, while you have the front of the engine in vi... Apr 28 2005, 07:16 AM
xitspd Joe,
One of my friends owns 928 International in ... Apr 28 2005, 07:22 AM
SLITS Or call APC (Automotive Parts Center) in Ontario, ... Apr 28 2005, 08:17 AM
Gint Rick'll have it on the road before you know it... Apr 28 2005, 08:48 AM
Dave_Darling Damn, that is way cool! Within hours, he has ... Apr 28 2005, 09:38 AM
CptTripps Yeah, but Rick could build that engine in his slee... Apr 28 2005, 10:35 AM
tesserra That critical tension adjustment is most likely wh... Apr 28 2005, 10:55 AM
Series9 Here's the carnage. The water pump is fucked.... Apr 28 2005, 12:20 PM
Series9 next Apr 28 2005, 12:21 PM
Series9 next Apr 28 2005, 12:22 PM
Series9 last Apr 28 2005, 12:23 PM
David_S Cool to hear that everything is working out so far... Apr 28 2005, 12:34 PM
Mike D. Damn Rick! your awsome ht... Apr 28 2005, 12:40 PM
LvSteveH Getting ribbed by 914 purists for having an access... Apr 28 2005, 12:41 PM
MJHanna Hey!!! take Rich to Sadies for Dinner ... Apr 28 2005, 12:45 PM
Curvie Roadlover I can't believe somebody resurrected this old ... Apr 28 2005, 12:47 PM
SpecialK ... Apr 28 2005, 02:30 PM
rich brennick Yep, Curvie, I'm way too far away to check on ... Apr 28 2005, 02:43 PM
ThinAir914 I'm sure glad this didn't happen when Rick... Apr 28 2005, 02:45 PM
rick 918-S Thanks all, Dan pulled some strings and the pump i... Apr 28 2005, 03:10 PM
Travis Neff That's naaasty. Good luck on the replacement ... Apr 28 2005, 03:42 PM
PorscheTom Ouch! That's some picture of damage. The... Apr 28 2005, 03:46 PM
redshift The level of knowledge around here makes me laugh ... Apr 28 2005, 05:07 PM
Aaron Cox is the block going to survive???? ... Apr 28 2005, 05:10 PM
jim912928 Yes, euro 928 engines and all 32V 928 engines are ... Apr 28 2005, 05:35 PM
SLITS Rich....
I just talked to our water pump expert f... Apr 28 2005, 06:01 PM
Flat VW Apr 29 2005, 08:46 PM
Howard Sounded pretty cheerful around 2pm CA time. Car ... Apr 29 2005, 09:14 PM
redshift Great job! Man, that's a fairly MAJOR prob... Apr 29 2005, 10:19 PM
iamchappy Keep her coming your almost home. Apr 29 2005, 10:21 PM
Verruckt They are going to shut down a section of I-35 in K... Apr 30 2005, 07:32 AM
David_S Well , I don't know how far he made it, but he... Apr 30 2005, 10:26 AM
Gint I just called Rick. He's already past K.C. an... Apr 30 2005, 12:28 PM
LuckieO I spoke to Rick a few hours ago and he said he was... Apr 30 2005, 10:20 PM
rick 918-S I'm home! Great to be here! You know w... Apr 30 2005, 11:56 PM
redshift WTG Man! You rock!
M Apr 30 2005, 11:58 PM
GWN7 Glad to hear you made home ht... May 1 2005, 12:00 AM
dan10101 Whoo Hoo! http://www.91... May 1 2005, 12:02 AM
rick 918-S <... May 1 2005, 12:16 AM
rick 918-S ... May 1 2005, 12:17 AM
rick 918-S ... May 1 2005, 12:19 AM
rick 918-S May 1 2005, 12:20 AM
ablose58 Glad you made it home ,Rick ... May 1 2005, 12:54 AM
BIGKAT_83 http://www.9... May 1 2005, 02:08 PM
David_S May 1 2005, 10:19 PM
914Timo Glad to hear you are at home, Rick.
I have read w... May 2 2005, 01:39 AM
Tom Perso Reading thru this makes me happy to be part of a g... May 2 2005, 04:26 AM
xitspd http://www.914world.com/bbs2/... May 2 2005, 07:24 AM
rick 918-S May 2 2005, 08:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:27 PM |
