| Series9 |
Apr 27 2005, 11:23 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Rick just called. He's 30 miles west of Albuquerque and his water pump is failing. He has water and is going to try to get her here, but Nico and I are on stand by with the Burb and a strong rope.
I guess he'll be a house guest for a couple of days. Any one have a 928 water pump you can overnight? |
| SLITS |
Apr 28 2005, 06:01 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Rich....
I just talked to our water pump expert from APC and showed him the images. He said it looks like the reman pump you installed had the impeller height set 1/32 - 1/16" to deep toward the block or the bearing was fitted to loose. With bearing failure (walking), the impeller can only move a few 32nds of an inch prior to the drive pulley hitting the bearing housing on the pump (this would limit the amount of digging into the block). Problems... With the wear on the water pump housing, the impeller could have a tendency to cavitate due to excess clearance....watch your cooling carefully... I didn't want to be the bearer of bad news but thought you might want this information. |
Series9 The Alien is failing! Apr 27 2005, 11:23 PM
Jenny Sucks! It's a good thing he's got club... Apr 27 2005, 11:25 PM
Aaron Cox have devek overnight a pump. i hear they are the 9... Apr 27 2005, 11:28 PM
ThinAir914 Bummer! When I saw him this afternoon he was ... Apr 27 2005, 11:34 PM
Series9 Apr 28 2005, 12:47 AM
rick 918-S The pump was a reman. I installed it late last sum... Apr 28 2005, 01:28 AM
ablose58 good luck rick http://www.914... Apr 28 2005, 03:32 AM
MJHanna Call Russ Kelso. He might have one laying around. Apr 28 2005, 05:45 AM
jim912928 If devek doesn't have one (unlikely)...you can... Apr 28 2005, 06:45 AM
CptTripps You are right...it couldn't have happened in a... Apr 28 2005, 07:09 AM
spare time toys Rick, while you have the front of the engine in vi... Apr 28 2005, 07:16 AM
xitspd Joe,
One of my friends owns 928 International in ... Apr 28 2005, 07:22 AM
SLITS Or call APC (Automotive Parts Center) in Ontario, ... Apr 28 2005, 08:17 AM
Gint Rick'll have it on the road before you know it... Apr 28 2005, 08:48 AM
Dave_Darling Damn, that is way cool! Within hours, he has ... Apr 28 2005, 09:38 AM
Joe Ricard Unfortunately this is not an easy job for a 928 mo... Apr 28 2005, 10:29 AM
CptTripps Yeah, but Rick could build that engine in his slee... Apr 28 2005, 10:35 AM
tesserra That critical tension adjustment is most likely wh... Apr 28 2005, 10:55 AM
Series9 Here's the carnage. The water pump is fucked.... Apr 28 2005, 12:20 PM
Series9 next Apr 28 2005, 12:21 PM
Series9 next Apr 28 2005, 12:22 PM
Series9 last Apr 28 2005, 12:23 PM
David_S Cool to hear that everything is working out so far... Apr 28 2005, 12:34 PM
Mike D. Damn Rick! your awsome ht... Apr 28 2005, 12:40 PM
LvSteveH Getting ribbed by 914 purists for having an access... Apr 28 2005, 12:41 PM
MJHanna Hey!!! take Rich to Sadies for Dinner ... Apr 28 2005, 12:45 PM
Curvie Roadlover I can't believe somebody resurrected this old ... Apr 28 2005, 12:47 PM
SpecialK ... Apr 28 2005, 02:30 PM
rich brennick Yep, Curvie, I'm way too far away to check on ... Apr 28 2005, 02:43 PM
ThinAir914 I'm sure glad this didn't happen when Rick... Apr 28 2005, 02:45 PM
rick 918-S Thanks all, Dan pulled some strings and the pump i... Apr 28 2005, 03:10 PM
Travis Neff That's naaasty. Good luck on the replacement ... Apr 28 2005, 03:42 PM
PorscheTom Ouch! That's some picture of damage. The... Apr 28 2005, 03:46 PM
redshift The level of knowledge around here makes me laugh ... Apr 28 2005, 05:07 PM
Aaron Cox is the block going to survive???? ... Apr 28 2005, 05:10 PM
jim912928 Yes, euro 928 engines and all 32V 928 engines are ... Apr 28 2005, 05:35 PM
Flat VW Apr 29 2005, 08:46 PM
Howard Sounded pretty cheerful around 2pm CA time. Car ... Apr 29 2005, 09:14 PM
redshift Great job! Man, that's a fairly MAJOR prob... Apr 29 2005, 10:19 PM
iamchappy Keep her coming your almost home. Apr 29 2005, 10:21 PM
Verruckt They are going to shut down a section of I-35 in K... Apr 30 2005, 07:32 AM
David_S Well , I don't know how far he made it, but he... Apr 30 2005, 10:26 AM
Gint I just called Rick. He's already past K.C. an... Apr 30 2005, 12:28 PM
LuckieO I spoke to Rick a few hours ago and he said he was... Apr 30 2005, 10:20 PM
rick 918-S I'm home! Great to be here! You know w... Apr 30 2005, 11:56 PM
redshift WTG Man! You rock!
M Apr 30 2005, 11:58 PM
GWN7 Glad to hear you made home ht... May 1 2005, 12:00 AM
dan10101 Whoo Hoo! http://www.91... May 1 2005, 12:02 AM
rick 918-S <... May 1 2005, 12:16 AM
rick 918-S ... May 1 2005, 12:17 AM
rick 918-S ... May 1 2005, 12:19 AM
rick 918-S May 1 2005, 12:20 AM
ablose58 Glad you made it home ,Rick ... May 1 2005, 12:54 AM
BIGKAT_83 http://www.9... May 1 2005, 02:08 PM
David_S May 1 2005, 10:19 PM
914Timo Glad to hear you are at home, Rick.
I have read w... May 2 2005, 01:39 AM
Tom Perso Reading thru this makes me happy to be part of a g... May 2 2005, 04:26 AM
xitspd http://www.914world.com/bbs2/... May 2 2005, 07:24 AM
rick 918-S May 2 2005, 08:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:54 PM |
