| Garland |
Apr 29 2005, 11:20 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I think I read you warm it in hot water first, is this correct?
| Aaron Cox |
Apr 29 2005, 11:26 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
B F H = Big Fuckin Hammer.
i softened mine with a heat gun, also worked great with rear sway drop link bushings |
Garland How do you install shifter firewall bushing? Apr 29 2005, 11:20 PM
Brad Roberts That will help...
Is the shift rod out of the car... Apr 29 2005, 11:22 PM
Garland The shift rear rod is out, the one in the tunnel i... Apr 29 2005, 11:23 PM
Brad Roberts BFH = Big F-ing Hammer
Is the engine in the car ?... Apr 29 2005, 11:25 PM
Garland O, I have them. http://www.9... Apr 29 2005, 11:28 PM
Brad Roberts http://www.914world.com/bbs2/htm... Apr 29 2005, 11:30 PM
Garland Easier? The engine is out, so with the tunnel rod ... Apr 29 2005, 11:39 PM
Aaron Cox thats the idea http://www.914world... Apr 29 2005, 11:40 PM
Garland Aaron, what size cam are you running? I have a 1.7... Apr 29 2005, 11:46 PM
Aaron Cox <... Apr 29 2005, 11:52 PM
Garland Forgot to mention 96 B/B kit also. I will run this... Apr 30 2005, 12:01 AM
McMark If the engine is in the car (I know it's not i... Apr 30 2005, 12:48 AM
9146986 You definately can't replace that bushing with... Apr 30 2005, 07:53 AM
jim912928 Do as Mark said (I've just done this)....move ... Apr 30 2005, 08:02 AM
SGB I used a vise- took both parts out of car and used... Apr 30 2005, 08:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:47 PM |
