> Why is my front stabilizer bar shifted to the left, help before I pull the tank.
Garland
post Apr 30 2005, 09:36 PM
Restoration Fanatic
The bar will rub the left strut when on the houst, and is shifted to the left also when sitting on the ground. It's a 73 stock bar, the mounts look OK, not torn.
Garland
post Apr 30 2005, 09:44 PM
Restoration Fanatic
I will pull the tank, but what could cause this? Bad bushing?
Garland   Why is my front stabilizer bar shifted to the left   Apr 30 2005, 09:36 PM
!   Check up where the bar goes thru the body....under...   Apr 30 2005, 09:40 PM
skline   If it ripped through, you can fix it with a kit fr...   Apr 30 2005, 09:44 PM
Garland   I will pull the tank, but what could cause this? B...   Apr 30 2005, 09:44 PM
Garland   The mount's look fine from the wheel well side...   Apr 30 2005, 09:47 PM
ArtechnikA   before you start getting radical and pulling parts...   May 1 2005, 05:43 AM
Garland   Thanks, I will post after I inspect it again.   May 1 2005, 07:45 AM
Eric_Shea   I would say two new proper sized nose cone bushing...   May 1 2005, 10:23 AM
rhodyguy   haynes states, "Secure the stabilizer lever so tha...   May 1 2005, 11:19 AM
Eric_Shea     May 1 2005, 01:24 PM
rhodyguy   ...put in that electric windshield washer pump...   May 2 2005, 08:25 AM
dmenche914   when your gas tank is out, get your fresh air blow...   May 2 2005, 11:35 AM
- Lo-Fi Version Time is now: 5th July 2025 - 02:11 AM
