> Slobber bottles..., suggestions needed
Rusty
post May 1 2005, 11:21 AM
I'm looking for a couple of slobber bottles. I need one for the /6 and one for the Aubergine (not purple) car.
I'm having some trouble actually finding them available online. Any suggested sources?
-Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
red914
post May 2 2005, 07:32 AM
...i believe in coyotes and time as an abstract...
QUOTE (Lawrence @ May 1 2005, 03:26 PM)
The purpose of a puke/slobber bottle is to capture the oil that escapes due to crankcase pressure, right?
If that oil escapes in vapor form, doesn't the bottle itself need to be vented so that it doesn't pop, or allow that oil-filled vapor escape to the air?
I have a problem pouring oil onto the ground or air, if I can prevent it. It goes into the environment. (IMG:http://www.914world.com/bbs2/html/emoticons/scuba.gif)
(note: this post will reveal my ignorance and lack of knowledge)
so, is this slobber bottle installed instead of routing the breather tubes into the airfilters, as i have seen on some cars? i think this was the cause of my late oil leak, which is now gone since rerouting the breather tubes into the air filters. did i do a bad thing?
Lawrence   Slobber bottles...   May 1 2005, 11:21 AM
rhodyguy   rusty, long ago b told me to buy a jax(?), jacks(?...   May 1 2005, 11:29 AM
SLITS   On our race cars, we used pint/quart metal cans wi...   May 1 2005, 11:35 AM
d914   the vintage thread used bilke water bottles and br...   May 1 2005, 01:24 PM
Eric_Shea   I was going to use a windshield washer bottle. I...   May 1 2005, 01:28 PM
lapuwali   Amusing things one has seen used as "slobber bottl...   May 1 2005, 02:14 PM
majkos   Slobber bottles!? http://www.9...   May 1 2005, 02:27 PM
Eric_Shea   The GT bottle was a windhsield washer bottle from ...   May 1 2005, 02:46 PM
!   Bikey Spandex fag water bottle and cages.....proll...   May 1 2005, 02:54 PM
d914   If I'm that Greg I'm always surprised when...   May 1 2005, 05:18 PM
d914   by the way, son keeps putting the camera on manual...   May 1 2005, 05:20 PM
!   Don't press the shutter down completely...let ...   May 1 2005, 05:23 PM
Lawrence   The purpose of a puke/slobber bottle is to capture...   May 1 2005, 05:26 PM
d914   DAH, http://www.914world.com/bbs2/h...   May 1 2005, 05:27 PM
!   <...   May 1 2005, 05:31 PM
datapace   How about this one from ebay. ...   May 1 2005, 05:43 PM
Aaron Cox     May 1 2005, 06:26 PM
J P Stein   This stylish number on the left is plastic & start...   May 1 2005, 06:37 PM
Dominic   Here is a JAZ breather bottle I found on ebay. Th...   May 1 2005, 07:07 PM
campbellcj   I went with an aluminum Canton bottle. A windshie...   May 1 2005, 11:20 PM
Aaron Cox   Eric Shea will this work for your GT? relatively ...   May 1 2005, 11:26 PM
red914   <...   May 2 2005, 07:32 AM
Eric_Shea   That would work... if it were stateside. I actual...   May 2 2005, 07:52 AM
red914   so, from the bottle it simply returns to the case?...   May 2 2005, 08:35 AM
SLITS     May 2 2005, 08:50 AM
rhodyguy   shane, you would eliminate the need to run any add...   May 2 2005, 09:23 AM
red914   actually, i am venting to two carbs now, Kevin; wi...   May 2 2005, 09:37 AM
Eric_Shea
  May 2 2005, 09:42 AM
rhodyguy   or the nearest storm water grate. esp if it drains...   May 2 2005, 09:46 AM
red914   thanks for the assurance, Kevin. it seems to be r...   May 2 2005, 09:48 AM
HotRod   Check with Summit Racing, they're primarily in...   May 2 2005, 11:48 AM
HotRod   Ooops, That should be... http://store.summitracin...   May 2 2005, 11:50 AM
HotRod   Odd, the link doesn't seem to work...just type...   May 2 2005, 11:53 AM
Eric_Shea   That's much closer to my $27.50 price. W...   May 2 2005, 12:57 PM
Eric_Shea   Rusty... jump on that one. It's the best deal...   May 2 2005, 01:05 PM
JmuRiz     May 2 2005, 01:06 PM
rhodyguy   in my tommy flanagan voice "YA, THAT'S THE TIC...   May 2 2005, 01:11 PM
brant   As mentioned on page one of this thread. We went w...   May 2 2005, 01:12 PM
Eric_Shea
  May 2 2005, 01:19 PM
brant   ...   May 2 2005, 01:28 PM
JmuRiz   Seems like most of the guys with these overflow bo...   May 2 2005, 01:41 PM
SLITS   ...   May 2 2005, 01:46 PM
rhodyguy   jim, those boxes are open around the top edge. not...   May 2 2005, 04:13 PM
Eric_Shea
  May 2 2005, 05:05 PM
HotRod   JMURiz, you don't want to mess with that box.....   May 3 2005, 08:29 AM
Eric_Shea
  May 3 2005, 08:31 AM
HotRod   It was pretty simple, but this is a race car and t...   May 3 2005, 08:41 AM
JmuRiz     May 3 2005, 09:02 AM
HotRod   I'll see what I can do about pics, I've go...   May 3 2005, 09:12 AM
J P Stein   A word for those considering mounting a "Breather"...   May 3 2005, 01:35 PM
MJHanna   I used the one with the drain pulg in the bottom. ...   May 3 2005, 02:08 PM
Oracle   FYI Here is the summit bottle with new connectors...   May 3 2005, 08:01 PM
Oracle   Here it is bolted down...   May 3 2005, 08:02 PM
Eric_Shea   It's Here! It's May 4th and it's ...   May 4 2005, 05:02 PM
J P Stein   If Summit was in the Porsche parts biddness, a goo...   May 4 2005, 05:14 PM
sixnotfour   Jegs is another Hot Rod supplier that is quick and...   May 4 2005, 07:02 PM
mskala   Lawrence, I thought your car was kinda stock, if y...   May 4 2005, 08:35 PM
Aaron Cox     May 4 2005, 11:04 PM
Lawrence     May 4 2005, 11:08 PM
JmuRiz     May 5 2005, 02:47 PM
rhodyguy   here you go read this one. k   May 19 2005, 10:46 AM
rhodyguy   the one from summit is MUCH too large for the engi...   May 22 2005, 02:21 PM
Eric_Shea   http://www.914world.com/bbs2/ht...   May 22 2005, 02:30 PM
rhodyguy   the wife asked me if i knew there was a box for me...   May 22 2005, 02:54 PM
Eric_Shea   Just think of all the things you could do/fix once...   May 22 2005, 02:57 PM
rhodyguy   LEAVE ME ALONE!!! http:...   May 22 2005, 03:01 PM
!   PANSY....I just finished the brake light fix, the ...   May 22 2005, 03:06 PM
rhodyguy   well i guess you're all kinds of legal now mik...   May 22 2005, 03:08 PM
- Lo-Fi Version Time is now: 24th August 2025 - 10:23 AM
