| Mueller |
May 2 2005, 10:39 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
sorry for the Andy-esque photo (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Started to read the install manual for the Link fuel injection/ignition controller last night as well as the wiring for the Mallory CDI which will be used as well (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Man, wiring is never fun, the hardest part I think will be laying everything out and figuring out how to run the wires so that it looks like a clean install....I'm still not sure if I'll be shrink tubing the entire harness or use the wire harness specific cloth-type tape. Attached image(s)
| lapuwali |
May 2 2005, 02:46 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
A goodly number of OEMs disagree with your experience regarding the split harness tubes, as a glance into the engine bays in quite a few recently manufactured cars will attest. Perhaps there's higher performance split tubing in use now than whatever you're familiar with. Some of this stuff is now rated for temps over 250dC. There's one outfit that sells some reflective stuff that they claim will survive one inch away from a 500dC heat source, like an exhaust pipe. I believe I indicated above that the ENDS of the wiring at the connectors should be heat-shrinked, so we agree there. I just don't like the idea of heat-shrinking the whole thing for serviceability reasons. I don't deny it will protect it, and perhaps will do a better job than the split tubing will. The tubing is mostly there to prevent chafing and to keep wires bundled and tidy. Since our engine bays are open, the sun can cause the insulation colors and labelling to fade over time without UV protection, which the tubing will also provide. |
Mueller Oh joy....engine wiring harness fun begins May 2 2005, 10:39 AM
McMark http://www.914world.com/bbs2/ht... May 2 2005, 10:52 AM
Mueller My wife does not like the camera phone either...we... May 2 2005, 11:06 AM
Aaron Cox you are a glutton for punishment mike,
and thats ... May 2 2005, 11:16 AM
Mueller ... May 2 2005, 11:23 AM
Aaron Cox May 2 2005, 11:24 AM
Mueller ... May 2 2005, 11:39 AM
Aaron Cox which dizzy?
the link enables you to make your ow... May 2 2005, 11:41 AM
Mueller the Mallory distributor will be used...I could use... May 2 2005, 11:51 AM
Aaron Cox how do you disable the mech advance on the unilite... May 2 2005, 11:53 AM
lapuwali To lay everything out, mount all of the components... May 2 2005, 11:53 AM
Mueller James,
all of my connectors are brand new and hav... May 2 2005, 12:08 PM
lapuwali May 2 2005, 12:40 PM
Mueller May 2 2005, 12:41 PM
Jeff Bowlsby Now you know I couldn't leave this one alone..... May 2 2005, 01:52 PM
TimT I also think split tube looks cheesy and cheap.. ... May 2 2005, 07:17 PM
TimT nutter butter peanut butter cookie May 2 2005, 07:18 PM
TimT burp May 2 2005, 07:19 PM
Mueller Hey Tim....what the heck is that connector attache... May 2 2005, 07:21 PM
TimT Mike, that connector would be a 26 pin weather-pa... May 2 2005, 07:32 PM
Mueller May 2 2005, 07:44 PM
lapuwali Tim, what's that braided stuff made out of? W... May 2 2005, 08:10 PM
Brad Roberts I must be doing something right.. finally.. I star... May 2 2005, 08:15 PM
Brad Roberts James,
I bought rolls and rolls of it from the el... May 2 2005, 08:17 PM
Mueller <... May 2 2005, 08:21 PM
TimT Yeap can be had in electronic supply houses... ... May 2 2005, 08:24 PM
TimT Heh Mikeholio lets the cat out
LOL May 2 2005, 08:24 PM
Brad Roberts Call me back Mueller.. I walked outside and missed... May 2 2005, 08:34 PM
Jeff Bowlsby James, modern cars do not have engine bays open to... May 2 2005, 08:42 PM
Brad Roberts Yes. I knew going in there was NO way the braided ... May 2 2005, 08:49 PM
cha914 Ok...since this is a wiring discussion...where the... May 2 2005, 09:22 PM
lapuwali May 2 2005, 10:11 PM
jonwatts Nylon braided harness covering can be bought in th... May 2 2005, 11:25 PM
Mueller May 3 2005, 09:15 AM
Mueller spent some time tonight on the new harness...oh bo... May 3 2005, 11:26 PM
Mueller it'll take a few revisions to get it perfect ... May 3 2005, 11:27 PM
Mueller for the GM Weatherpack connectors, I added a littl... May 3 2005, 11:30 PM
McMark Real pictures! http://www.... May 4 2005, 12:10 AM
Tom Perso http://www.914world.com/bbs2/h... May 4 2005, 04:34 AM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:16 PM |
