> Oh joy....engine wiring harness fun begins, starting to wire up the LINK fuel inject
Mueller
post May 2 2005, 10:39 AM
914 Freak!
sorry for the Andy-esque photo (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Started to read the install manual for the Link fuel injection/ignition controller last night as well as the wiring for the Mallory CDI which will be used as well (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Man, wiring is never fun, the hardest part I think will be laying everything out and figuring out how to run the wires so that it looks like a clean install....I'm still not sure if I'll be shrink tubing the entire harness or use the wire harness specific cloth-type tape.
JeffBowlsby
post May 2 2005, 08:42 PM
James, modern cars do not have engine bays open to direct water like ours do...That split in the corrugeted casing is not waterproof. Consider where water will end up when the engine bay is exposed rain...yes, inside the harness...Corrugated casing is not optimum or even appropriate for our cars engine bays. My wifes 5-series Bimmer has sealed harness even in the rear trunk, don't know about other modern cars. I have taken apart at leat 200 of our 914s harnesses...I see the kind of harsh conditions they are exposed to...and how the OEM harnesses have performed.
Now if its to be used in protected locations...I couldn't see a problem with that.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Same with the polyester braided sleeving guys, its not waterproof. While its great for abrasion resistance, it wont keep the dirt/fluids out from where it counts. I think heat resistance may be questoinable too, but I would have to check the products specs.
Just MHO...YMMV...you are free to disagree....
Mueller   Oh joy....engine wiring harness fun begins   May 2 2005, 10:39 AM
McMark   http://www.914world.com/bbs2/ht...   May 2 2005, 10:52 AM
Mueller   My wife does not like the camera phone either...we...   May 2 2005, 11:06 AM
Aaron Cox   you are a glutton for punishment mike, and thats ...   May 2 2005, 11:16 AM
Mueller   ...   May 2 2005, 11:23 AM
Aaron Cox     May 2 2005, 11:24 AM
Mueller   ...   May 2 2005, 11:39 AM
Aaron Cox   which dizzy? the link enables you to make your ow...   May 2 2005, 11:41 AM
Mueller   the Mallory distributor will be used...I could use...   May 2 2005, 11:51 AM
Aaron Cox   how do you disable the mech advance on the unilite...   May 2 2005, 11:53 AM
lapuwali   To lay everything out, mount all of the components...   May 2 2005, 11:53 AM
Mueller   James, all of my connectors are brand new and hav...   May 2 2005, 12:08 PM
lapuwali     May 2 2005, 12:40 PM
Mueller     May 2 2005, 12:41 PM
Jeff Bowlsby   Now you know I couldn't leave this one alone.....   May 2 2005, 01:52 PM
lapuwali     May 2 2005, 02:46 PM
TimT   I also think split tube looks cheesy and cheap.. ...   May 2 2005, 07:17 PM
TimT   nutter butter peanut butter cookie   May 2 2005, 07:18 PM
TimT   burp   May 2 2005, 07:19 PM
Mueller   Hey Tim....what the heck is that connector attache...   May 2 2005, 07:21 PM
TimT   Mike, that connector would be a 26 pin weather-pa...   May 2 2005, 07:32 PM
Mueller     May 2 2005, 07:44 PM
lapuwali   Tim, what's that braided stuff made out of? W...   May 2 2005, 08:10 PM
Brad Roberts   I must be doing something right.. finally.. I star...   May 2 2005, 08:15 PM
Brad Roberts   James, I bought rolls and rolls of it from the el...   May 2 2005, 08:17 PM
Mueller   <...   May 2 2005, 08:21 PM
TimT   Yeap can be had in electronic supply houses... ...   May 2 2005, 08:24 PM
TimT   Heh Mikeholio lets the cat out LOL   May 2 2005, 08:24 PM
Brad Roberts   Call me back Mueller.. I walked outside and missed...   May 2 2005, 08:34 PM
Jeff Bowlsby   James, modern cars do not have engine bays open to...   May 2 2005, 08:42 PM
Brad Roberts   Yes. I knew going in there was NO way the braided ...   May 2 2005, 08:49 PM
cha914   Ok...since this is a wiring discussion...where the...   May 2 2005, 09:22 PM
lapuwali     May 2 2005, 10:11 PM
jonwatts   Nylon braided harness covering can be bought in th...   May 2 2005, 11:25 PM
Mueller     May 3 2005, 09:15 AM
Mueller   spent some time tonight on the new harness...oh bo...   May 3 2005, 11:26 PM
Mueller   it'll take a few revisions to get it perfect ...   May 3 2005, 11:27 PM
Mueller   for the GM Weatherpack connectors, I added a littl...   May 3 2005, 11:30 PM
McMark   Real pictures! http://www....   May 4 2005, 12:10 AM
Tom Perso   http://www.914world.com/bbs2/h...   May 4 2005, 04:34 AM
Mueller     May 4 2005, 09:08 AM
Mueller   James or anyone else: any real difference between...   May 4 2005, 04:56 PM
lapuwali   Not that I know of, no. Resistors are basically j...   May 4 2005, 05:32 PM
Mueller   <...   May 4 2005, 05:39 PM
Mueller   now I know why I don't throw too many things a...   May 4 2005, 06:10 PM
Mueller   bottom view, I still need to figure out how I will...   May 4 2005, 06:11 PM
Aaron Cox   thats a lot of heatsync.... where are you going t...   May 4 2005, 06:15 PM
Britain Smith   On the topic of heat sinks, where can I get some n...   May 4 2005, 07:11 PM
Mueller     May 4 2005, 07:46 PM
Mueller   ditched the stock relay board....had to come up wi...   May 26 2005, 03:23 PM
Mueller   i then soldered them to female sockets from the 12...   May 26 2005, 03:25 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:39 AM
