Suspension ear reinforcement, Would this work? (pic) |
smrz914 |
May 3 2005, 09:02 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
I played around with photoshop a little bit. I hope 914RS doesn't mink I used his picture.
Anyway, instead of having a tube go from the ear to the firewall, I thought that one could take some sheetmetal and create a shelf. I don't thin this will work for /4 but it might for converted cars. I thought a cross section might look like _____ |_____\__________ Would this be strong enough? Just seeing if there is a nice way of doing the brace. So It would be like having another shelf. I don't know how low the engine mount goes but I think one could work around that. On the ear the attachment point would be pretty low and be able to handle movement better. On the firewall site it would attach to the back edge of the floorpan. Attached image(s) |
Jeroen |
May 4 2005, 06:51 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
here's what I'm planning to do
weld a piece of 2" tube around the nut then tie braces to that (braces will be weld to both the 2" piece of tubing as the susp.ear itself) All the cracks I've seen are either at the nut or just above it I feel the braces pictured above don't reinforce that area This should Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:44 PM |
