> My new powder coating oven..., for satisfying my DWD needs!
bondo
post May 4 2005, 08:57 PM
I built this oven a while back, but I couldn't get it over about 275 degrees. I recently added a layer of R13 insulation to the inside, and now it gets up to 400 no problem. It takes about 30 mins to get there, so a total cure takes 50 mins. I did one test part (an old water pump impeller) and it came out great.
I used the control circuitry from an old microwave/convection oven to turn on and off a 3 element quartz heater (about 1600 watts). I just set the temp for 400, the time for 50 minutes, and it beeps when it's done! (and turns off)
I still have a few kinks to work out (like a structure for the ceiling to hang things from), and I need to get better at the application of the powder, but at least I can get up to and hold 400 degrees. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
bondo
post May 5 2005, 06:00 PM
I would think elements from 2 kitchen ovens would be overkill. How hot do you need to get, and how fast do you need to get there? I'm running 1600 watts from 115v. That's about 14 amps. Most kitchen ovens run on 230. That will complicate things, especially switching (230v relays are more expensive, and you need to switch 2 poles for it to be safe). If you gut a countertop convection oven, and use its elements and circuitry you should do pretty well, as long as you have plenty of insulation.
- Lo-Fi Version Time is now: 11th July 2025 - 02:43 PM
