> Will this work?, Tired of blowing dust.
Pugbug
post May 5 2005, 11:54 AM
My engine shroud blows the air straight down and blows dust everywhere, so I want to try these baffles I made up to blow it out my rear.
Can anyone see a reason why this would be a bad thing?
Reiche
post May 6 2005, 12:08 AM
QUOTE (Pugbug @ May 5 2005, 10:47 AM)
Stock air guides won't fit this shroud, so I'll try these, but keep a close eye on the temps.
Looks great. With your fab skills, I think it would be easy to make some tins that replicated the factory ones in function. Right now, your cooling air is cooling the top of your engine well, but it is missing the hottest parts of the heads and cylinders: the bottoms. If you can channel the air around those bottom-side curves a little (like the factory did) I think you will run much cooler. At least your temps would be more even, which is as important. I wouldn't use the stock type 4 bottom tin though. A type 1-style bottom tin would do (basically a flat plate under the "cleavage" between the two cylinder barrels.)
Pugbug   Will this work?   May 5 2005, 11:54 AM
brant   don't have any personal experience. and don...   May 5 2005, 12:01 PM
mattillac   maybe drill some holes in it or add some louvres(?...   May 5 2005, 12:19 PM
rhodyguy   wouldn't be easier to get the proper air guide...   May 5 2005, 12:28 PM
mattillac   he already made the deflectors tho. <...   May 5 2005, 12:34 PM
Pugbug   Stock air guides won't fit this shroud, so I...   May 5 2005, 12:47 PM
nebreitling   interesting exhaust.. are those the 75-75 stubs t...   May 5 2005, 12:49 PM
SirAndy     May 5 2005, 12:54 PM
Pugbug   I have no idea what the exhaust is from...Was on t...   May 5 2005, 12:56 PM
Pugbug   I've modified the tins....Added louvers, and c...   May 5 2005, 05:52 PM
StratPlayer   Ya didn't waste any time. Looks good, hope it...   May 5 2005, 05:55 PM
Reiche     May 6 2005, 12:08 AM
messix   ot nice cj hood. whats the rest of it look li...   May 6 2005, 12:15 AM
jgiroux67   I'm interested about that exhaust. What year e...   May 6 2005, 12:56 AM
McMark   Am I the only one who doesn't understand the m...   May 6 2005, 01:02 AM
Pugbug   McMark; The shroud on this engine bows a lot of ai...   May 6 2005, 06:23 AM
URY914   You should email RicerChris pictures of those head...   May 6 2005, 07:50 AM
davep   It appears you are missing the lower air guides. T...   May 6 2005, 08:21 AM
Tom Perso   Since I ran a DTM shroud on my 2270 when it was in...   May 6 2005, 08:28 AM
brant   Larry, I gotta say.. nice fab work! brant   May 6 2005, 08:36 AM
McMark   Damn! That's a lot of air. No wonder the...   May 6 2005, 09:16 AM
type11969   T-1 engines used deflector tins similar to what yo...   May 6 2005, 10:52 AM
Pugbug   DaveP; Air guides?...Are you referring to these? T...   May 6 2005, 02:47 PM
mattillac     May 6 2005, 05:53 PM
Reiche     May 6 2005, 06:47 PM
Reiche   Also, with an upright cooling system like that, it...   May 6 2005, 06:48 PM
Pugbug   Reiche; Thanks for the photo....I think I may ha...   May 6 2005, 09:30 PM
Tom Perso   T1 tins are generally better for upright converted...   May 6 2005, 09:38 PM
McMark   You can't remove the under cylinder tin from a...   May 6 2005, 10:26 PM
Pugbug   Update...I've made up air guides for the shrou...   May 9 2005, 05:44 PM
Reiche   Well done. I think that will work much better for ...   May 9 2005, 10:37 PM
jgiroux67   So vw bus headers/exhaust work on our engines? I t...   May 9 2005, 11:19 PM
Jake Raby   Those head pipes are from a 75-77 Bus.... The rest...   May 10 2005, 12:03 AM
Pugbug   Thanks for your comments Jake. The exhaust system...   May 10 2005, 06:58 AM
Air_Cooled_Nut     Jul 17 2005, 12:26 PM
- Lo-Fi Version Time is now: 31st July 2025 - 11:35 PM
