Pugbug
May 5 2005, 11:54 AM
My engine shroud blows the air straight down and blows dust everywhere, so I want to try these baffles I made up to blow it out my rear.
Can anyone see a reason why this would be a bad thing?
brant
May 5 2005, 12:01 PM
don't have any personal experience.
and don't want to sound negative either...
but off the top of my head, I would think that the shroud would increase motor temps (oil and head) because it would radiate heat back and because it would prevent some heat from escaping...
again, don't take this negative and maybe temp isn't an issue for you. Nice fab work though!
brant
mattillac
May 5 2005, 12:19 PM
maybe drill some holes in it or add some louvres(?) so it's more like a diffuser than a
shield.
rhodyguy
May 5 2005, 12:28 PM
wouldn't be easier to get the proper air guide plates for your engine application?
k
mattillac
May 5 2005, 12:31 PM
he already made the deflectors tho.
and buying stuff costs $$$.
mattillac
May 5 2005, 12:33 PM
louvers...
tat2dphreak
May 5 2005, 12:34 PM
QUOTE (rhodyguy @ May 5 2005, 01:28 PM) |
k |
I was thinking the same...
if you have trouble finding them cheap, LMK, I know a guy who parted several cars last year and I have bought several parts from...
Pugbug
May 5 2005, 12:47 PM
Stock air guides won't fit this shroud, so I'll try these, but keep a close eye on the temps.
nebreitling
May 5 2005, 12:49 PM
interesting exhaust.. are those the 75-75 stubs turned backwards? giving the mating angles, i thought they would not work in that orientation?
May 5 2005, 12:54 PM
QUOTE (brant @ May 5 2005, 10:01 AM) |
I would think that the shroud would increase motor temps (oil and head) because it would radiate heat back and because it would prevent some heat from escaping... |
moving air under the engine helps with cooling, that's why the factory added the "flaps" to the lower firewall in later years ...
you'll probably see higher oil temps ...
Andy
Pugbug
May 5 2005, 12:56 PM
I have no idea what the exhaust is from...Was on the car when I got it, along with twin cherry bomb mufflers. They are history now, but man was it ever loud!
I think I'll take Mattillac's suggestion and put some louvers in the baffles. I think that will minimize any radiant heat created. I'll also paint them flat black.
Thanks for the input all.
Pugbug
May 5 2005, 05:52 PM
I've modified the tins....Added louvers, and cut a wider opening in the front......Thanks for the tips guys.
StratPlayer
May 5 2005, 05:55 PM
Ya didn't waste any time. Looks good, hope it works for you...
Reiche
May 6 2005, 12:08 AM
QUOTE (Pugbug @ May 5 2005, 10:47 AM) |
Stock air guides won't fit this shroud, so I'll try these, but keep a close eye on the temps. |
Looks great. With your fab skills, I think it would be easy to make some tins that replicated the factory ones in function. Right now, your cooling air is cooling the top of your engine well, but it is missing the hottest parts of the heads and cylinders: the bottoms. If you can channel the air around those bottom-side curves a little (like the factory did) I think you will run much cooler. At least your temps would be more even, which is as important. I wouldn't use the stock type 4 bottom tin though. A type 1-style bottom tin would do (basically a flat plate under the "cleavage" between the two cylinder barrels.)
messix
May 6 2005, 12:15 AM
ot
nice cj hood.
whats the rest of it look like [what it mounts up to]
i have a '75 cj 5 built for the trail
jgiroux67
May 6 2005, 12:56 AM
I'm interested about that exhaust. What year engine do you have?
McMark
May 6 2005, 01:02 AM
Am I the only one who doesn't understand the motivation for this? You "blowing dust"? WTF?
Pugbug
May 6 2005, 06:23 AM
McMark;
The shroud on this engine bows a lot of air straight down, so whenever I encounter gravel or sandy roads...(Like a construction area) often I have to stop and wait. When I do there is a major sand storm rising from under the car.
That is me waiting on the other side of those gates.
Josh; The engine was originaly a 1.8 litre. It's been increased to 1910cc. I'm not sure, but I'm thinking the exhaust may be bus parts??
URY914
May 6 2005, 07:50 AM
You should email RicerChris pictures of those headers. He is the expert in 914 exhaust systems. I've never seen a seen one like that before.
BTW- we have two Pugs. Great dogs.
Paul
davep
May 6 2005, 08:21 AM
It appears you are missing the lower air guides. This may cause uneven cylinder cooling and that may be a bad thing. What I'm thinking of is that the bottoms of the cylinders will run much hotter since the airflow bypasses them. This could cause the running cylinders to be slightly out of round.
Tom Perso
May 6 2005, 08:28 AM
Since I ran a DTM shroud on my 2270 when it was in the bug, I ran T1 air deflectors and they cooled great. Get those on the car, plus their dirt cheap ($3 each or so?)
Tom
brant
May 6 2005, 08:36 AM
Larry,
I gotta say..
nice fab work!
brant
McMark
May 6 2005, 09:16 AM
Damn! That's a lot of air. No wonder the DTM cools so nice.
type11969
May 6 2005, 10:52 AM
T-1 engines used deflector tins similar to what you have created, instead of getting a blast of air straight down, you get it straight back. I would think this would help temps at idle if stuck in traffic, since if the hot air was just blowing striaght down, the heat would have a tendency to rise back up and get the engine hotter.
Pugbug
May 6 2005, 02:47 PM
DaveP;
Air guides?...Are you referring to these? They are on the engine, and the engine is in the car now. Just have to hook everything up.
mattillac
May 6 2005, 05:53 PM
QUOTE (messix @ May 5 2005, 10:15 PM) |
ot nice cj hood.
i have a '75 cj 5 built for the trail |
dunno? random google pic.
Reiche
May 6 2005, 06:47 PM
QUOTE (Pugbug @ May 6 2005, 12:47 PM) |
Air guides?...Are you referring to these? |
I was referring to part numbers 59, 60, 62 and 63 on this diagram.
Reiche
May 6 2005, 06:48 PM
Also, with an upright cooling system like that, it may cool better with the type 1 bottom tins than the type 4 tins.
Pugbug
May 6 2005, 09:30 PM
Reiche;
Thanks for the photo....I think I may have those air guides in the shop. I have a dismantled 1.7 engine out there. I'll see if I can make them fit some how. I don't have any type 1 undertins though. The engine has been installed today, and I'm not sure that I could get the type 4 undertins off....But I'll scope it out anyway.
Why do you think the type one tins would be better??
Tom Perso
May 6 2005, 09:38 PM
T1 tins are generally better for upright converted motors. I would suggest using them over the stock T4 ones, since they are designed just for pancake cooling.
Tom
McMark
May 6 2005, 10:26 PM
You can't remove the under cylinder tin from a T4 without removing the pushrod tubes. If you want them out in one pieces that is...
Pugbug
May 9 2005, 05:44 PM
Update...I've made up air guides for the shroud since the stock ones won't fit, and you guys got me all worried!
Tell me what you think.
Reiche
May 9 2005, 10:37 PM
Well done. I think that will work much better for cooling. If not, you could trim the ends of those new baffles until it does. Do you have a CHT gauge? Keep us posted.
Your dust problem should be solved too.
jgiroux67
May 9 2005, 11:19 PM
So vw bus headers/exhaust work on our engines? I thought the heads were different?
Jake Raby
May 10 2005, 12:03 AM
Those head pipes are from a 75-77 Bus.... The rest of the system is pure junk..
The Bus head pipes will work and are the same as the 914 right up till August of 1978 when the heads on the bus changed to a square port... The 914 heads are not magical in this area..
As for the tin you have made, it should work fine.. The stock TI engine had a tin just like that and it actually helps draw air from the engine as vehicle speed and fan pressure increases...
BTW- Make sure you run a 4-1 collector with that exhaust, not duals, these engines MUST have a collecteor and the nicer it is the better! I have seen a TWENTY FIVE percent power loss when going to dual exhaust without an collector/extractor on a TIV engine!
Pugbug
May 10 2005, 06:58 AM
Thanks for your comments Jake.
The exhaust system is basically what was on it when I bought the car. I've only put quieter mufflers on it. It is only temporary until I decide which system I want....and can afford.
I want the best I can get, but it must be fairly quiet.
Air_Cooled_Nut
Jul 17 2005, 12:26 PM
QUOTE (Pugbug @ May 5 2005, 09:54 AM) |
Can anyone see a reason why this would be a bad thing? |
Nothing wrong from a Type 3 person's point of view since that is how the stock T3 cooling tin works
I even use the stock pieces on my 2007cc T3 motor...no problems with over-heating
