> Speedo trim rings, ways to fasten
spunone
post May 6 2005, 05:47 PM
Thinking about makin trim rings for our gauges .I know they allready make them but seem a little pricey.How do they attach with silicon or just a press fit.??
StratPlayer
post May 6 2005, 06:36 PM
StratPlayer
Just cut yourself off a few small pieces of tape and place down inside the groove of the trim ring, then press the ring over the existing ring and wala its in place and isn't going anywhere. Its great for when you pull the gauges out the ring just comes off easy enough and then you can take out your tach, speedo, etc. Then just put the right back on after your finished doing what you need to do to the gauge. Once there on they don't move they stay in place.
spunone   Speedo trim rings   May 6 2005, 05:47 PM
Aaron Cox     May 6 2005, 05:48 PM
spunone   Thanks Aaron but that sounds a little cheesey way ...   May 6 2005, 05:53 PM
spunone   Also I'll leave them raw alum and you can fini...   May 6 2005, 05:54 PM
Aaron Cox     May 6 2005, 05:55 PM
scotty b   http://www.914world.com/bbs2/...   May 6 2005, 05:59 PM
spunone   Hint hint not ! I will make some ever since...   May 6 2005, 06:08 PM
StratPlayer   I used trim tape, that is what they recommend for ...   May 6 2005, 06:26 PM
StratPlayer   lkhgdf;gda   May 6 2005, 06:26 PM
spunone   Where do you apply the tape on the edge or inside ...   May 6 2005, 06:30 PM
StratPlayer   Just cut yourself off a few small pieces of tape a...   May 6 2005, 06:36 PM
spunone   Very cool where can I source the tape?   May 6 2005, 06:39 PM
StratPlayer   You can get the tape at any FLAPS. Get the trim t...   May 6 2005, 06:43 PM
spunone   About how thick is the tape ???   May 6 2005, 06:45 PM
StratPlayer   Maybe 1/8" very plyable.   May 6 2005, 06:47 PM
Aaron Cox   so paul.... you need a beta tester?   May 6 2005, 06:55 PM
spunone   Don't tell me SLITS is gonna loan ya da Money ...   May 6 2005, 07:02 PM
Korijo   if they're as good as the filler neck, i'l...   May 6 2005, 11:58 PM
bondo   Are you going to be making any of the 911 clock si...   May 7 2005, 12:02 AM
spunone   Sorry only the 3 guage for now http://www.914world.com/bbs2/ht...   May 23 2005, 09:10 AM
spunone   Not yet had a few personal projects I need to fini...   May 23 2005, 09:25 AM
JmuRiz   Ahhh, totally understand, maybe in 2 years you...   May 23 2005, 09:29 AM
- Lo-Fi Version Time is now: 1st August 2025 - 12:32 PM
