OK! now im lost...., help...help.......help |
xsboost90 |
May 6 2005, 07:44 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
get the gas tank all mounted in and nice, then notice i forgot to switch out the old rubber fuel lines, so out w/ the tank and put the new lines on. Get the tank back in, rerun some botched PO wiring under the hood, put on some wire loom covering, now its time to pull the old motor out and have a look see......now im lost.
see, im a 944 guy, could build one in my sleep, this thing is all flattend out and squished!! Problem is my haynes manual sucks. The guy who built the motor i think mistakenly ran some pvc line instead of fuel line and its all hard, so i know ill be putting in some real fuel line. I have a bunch of little holes and plugs and such that i have no idea where things go, and the instructions for my crane cam optic ignition is so vague, im not even sure it has instructions for my distributor. Here is every pic i can think of...I need some advice. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) heres my distributor. So i take the points and condensor off....how do i find tdc w/ the engine on the stand w/ no flywheel?? Any pics of how to mount the optics, i have an idea but not which direction. Attached image(s) |
nebreitling |
May 6 2005, 08:08 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
third pic is the vent to the head. you should plug it for now just so as crap doesn't get into it, but eventually you'll want to set a barb down in there in order breathe them (w/ hose, into a breather box or something).
the 'plug that obviously isn't used' is your oil pressure sender. re. the crane, everything you need is there, it's just a bit of a pain to set up. re. fuel lines, you'll have a send and a return from the tank into the engine bay, look at the pelican article (above) for orientation of them. good luck. use the search function and you'll figure things out! |
Lo-Fi Version | Time is now: 8th June 2024 - 06:43 AM |
