| xsboost90 |
May 6 2005, 07:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
get the gas tank all mounted in and nice, then notice i forgot to switch out the old rubber fuel lines, so out w/ the tank and put the new lines on. Get the tank back in, rerun some botched PO wiring under the hood, put on some wire loom covering, now its time to pull the old motor out and have a look see......now im lost.
see, im a 944 guy, could build one in my sleep, this thing is all flattend out and squished!! Problem is my haynes manual sucks. The guy who built the motor i think mistakenly ran some pvc line instead of fuel line and its all hard, so i know ill be putting in some real fuel line. I have a bunch of little holes and plugs and such that i have no idea where things go, and the instructions for my crane cam optic ignition is so vague, im not even sure it has instructions for my distributor. Here is every pic i can think of...I need some advice. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) heres my distributor. So i take the points and condensor off....how do i find tdc w/ the engine on the stand w/ no flywheel?? Any pics of how to mount the optics, i have an idea but not which direction. Attached image(s)
| xsboost90 |
May 6 2005, 08:38 PM
nice! thanks for the info, im feeling alittle better! The optic ignition, does this have to be put in a certain spot, like exactly on number one?
oh yeah i get the whole valve thing, been there before. |
xsboost90 OK! now im lost.... May 6 2005, 07:44 PM
xsboost90 here is the parts i have for it.. May 6 2005, 07:45 PM
xsboost90 what does this do? do i need to plug it? May 6 2005, 07:45 PM
xsboost90 and these??? http://www.914... May 6 2005, 07:46 PM
xsboost90 a plug that obviously isnt used? May 6 2005, 07:47 PM
xsboost90 how exactly does my fuel lines hook up, i have two... May 6 2005, 07:48 PM
grasshopper ... May 6 2005, 07:53 PM
mihai914 Go to the bird board and look up in the 914 tech s... May 6 2005, 07:56 PM
markb One tip, DON'T use chopsticks to find TDC. May 6 2005, 08:00 PM
nebreitling third pic is the vent to the head. you should plu... May 6 2005, 08:08 PM
Travis Neff To find TDC on number 1, rotate the engine and loo... May 6 2005, 08:08 PM
SGB thats right, the cooling fan has a mark that is vi... May 6 2005, 08:29 PM
Travis Neff Picture is worth a thousand words - just remember ... May 6 2005, 08:34 PM
brp914 If you really insist on putting that optical thing... May 6 2005, 08:40 PM
wilchek maybe this will help with lines May 7 2005, 01:44 PM
wilchek and closer May 7 2005, 01:46 PM
wilchek and sensor looks like green/red wire goes to it. May 7 2005, 01:55 PM
wilchek it looks like it comes out of wiring harness here May 7 2005, 01:58 PM
xsboost90 ok, figured out the fuel lines, i think the guy ha... May 7 2005, 03:10 PM
Type 4 Flywheel dowel pin will be pointed at #3 both valv... May 7 2005, 03:19 PM
xsboost90 anyone have some pressure plate bolts? I had some ... May 7 2005, 03:26 PM
Type 4 They are 8mm x 18mm.
Check Ace Hardware or Flaps.... May 7 2005, 03:44 PM
xsboost90 its under there! I would rather get some bolts... May 7 2005, 03:51 PM
Dead Air You can use the markings on the head of the bolt t... May 7 2005, 09:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:09 PM |
