Finally Pulled the Heads, Not What I expected At All |
d7n7master |
May 7 2005, 02:42 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi All,
Well, by now this is ancient history & probably by now lost on some old 914thread since it's been quite a while since I dropped the engine. At the time, there was a HARD knock accompanied by really low power. As in she wouldn't pull third gear- knocked HARD - but still got me home. I expected a dropped valve seat & maybe even some piston damage. From the looks of these heads - I was wrong all around. Next step obiously is to split the case. I'm sittin' here basically dumbfounded. What could the hard knock - coupled with could the low power - have come from if it's not associated with the heads? I haven't even cleaned the heads yet - & they look pretty damn good. Pistons look pretty good 2. Check out my picz & PLEASE give me a clue.. Attached image(s) |
Gary |
May 7 2005, 04:22 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Did you check the lifters? Maybe you wiped a cam. Was the mode of failure on mine - lifter fell apart. Nast ugly noises from the middle of the motor and no power... Coulda spun a bearing... You should find out when you splt the case.
Lo-Fi Version | Time is now: 31st May 2024 - 06:34 PM |
