DougC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 ![]() |
OK, I've installed hard fuel lines in the 914 before I install the six, and need to figure out how I'll be making the connection to the stock CIS fuel connections. First, I guess I need the thread count (on the CIS side) to have hoses made up...what size hoses? AN or stock type? Then, to connect these hoses to the accumulator and filter, then to the hard lines that I've install - will standard hose clamps work? Or is there a better way, like buying a flare tool and use some kind of fitting to connect it to the hose I'll be using? I feel so lame when it comes to plumbing this stuff but I need to get it right, so any and all advice is appreciated. TIA!
Doug C |
DougC |
OK, after reviewing some archived threads looks like the AN-6 if definately the popular choice. How and who to ask about the adapters for the stock Porsche CIS fittings? I assume standard AN fittings aren't compatable with the metric fittings Porsche uses, right? Also, is it possible to add AN-6 fittings to the hard metal fuel lines that I've installed (they don't have any kind of end on them, just cut off).
Doug C |
Lo-Fi Version | Time is now: 6th July 2025 - 10:39 AM |
