Full Version: Making Hard Fuel line connections
DougC
OK, I've installed hard fuel lines in the 914 before I install the six, and need to figure out how I'll be making the connection to the stock CIS fuel connections. First, I guess I need the thread count (on the CIS side) to have hoses made up...what size hoses? AN or stock type? Then, to connect these hoses to the accumulator and filter, then to the hard lines that I've install - will standard hose clamps work? Or is there a better way, like buying a flare tool and use some kind of fitting to connect it to the hose I'll be using? I feel so lame when it comes to plumbing this stuff but I need to get it right, so any and all advice is appreciated. TIA!
Doug C
ArtechnikA
i did all the CIS connections in my ur-GTI Rabbit in AN-6. hose ends and adapters were available for all the fittings. i donno what all you're trying to connect on your car, and i don't know the 911 fitting sizes. but i'd have to guess there are Earl's hose ends and adapter fittings for all that stuff too...
DougC
OK, after reviewing some archived threads looks like the AN-6 if definately the popular choice. How and who to ask about the adapters for the stock Porsche CIS fittings? I assume standard AN fittings aren't compatable with the metric fittings Porsche uses, right? Also, is it possible to add AN-6 fittings to the hard metal fuel lines that I've installed (they don't have any kind of end on them, just cut off).
Doug C
ArtechnikA
Earl's
on my car, the fitting into the fuel distributor was the same size/thread as a Weber carburetor. there are several Earl's hose ends that connect directly to this fitting, or you can get an adapter and use a standard AN-6 37-deg flare hose end. in my case, it was most convenient to use an adapter and a 120-deg tube hose end, for example.
there are banjo-bolt hose ends for (e,g,) the fuel pump.
the hard one was the accumulator, because the one in that car used two male ports. but there were (fairly new at the time - few years ago now) some power-steering adapters that used the same threads and with an appropriate O-ring held the pressure just fine.
you can either get a 37-deg flaring tool and flare the hardline (don't forget to put the ferrule on the line first!) or use compression fittings.
on my car, tank->pump->accumulator->filter->fuel distributor->tank it was about $400 all told. there's a bunch of different kinds and grades of hose; i've only used the Perform-O-Flex hose which is easy to work with and has the largest selection of specialty hose ends. it's not the cheapest, but the hose is not the biggest part of the expense - the fittings are...
lapuwali
And don't be tempted to cheap out here, as CIS runs very high fuel pressure between the tank and the fuel distributor. I haven't seen 911 CIS fittings in 5 years, so I'm afraid I can't offer any more help.
