New V-Caliper Teaser |
Eric_Shea |
May 10 2005, 01:20 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We're about done with the parts list on the new V-Caliper.
This allows the use of vented rear rotors on your 5-lug conversions. There is talk of a 4 lug vented rotor as well but we need to gauge interest for final pricing. These will be sold as completed calipers on an exchange basis similar to our regular caliper rebuild service. They will come completed and with pins and rotor spacers. They will come in "Silver" zinc only. Fasteners will be 7mm hex head to accomodate early (single bleeder) or late (dual bleeder) calipers. Enjoy the show... Attached image(s) |
Eric_Shea |
May 11 2005, 11:46 AM
Let me get to a few questions:
Pricing - It's still up in the air. I'd personally like to see $395.00 but there are a "lot" of parts here and they're all custom. I started thinking, "how much can some spacers cost?" Well, not that much but, then you'll need custom pins (914 pins are funky) with an additional 10mm in the center. Then there are a few extra inner seals, not much again but $1.00 each if you want good quality high-temp o-rings. Now that the caliper is 10mm wider the rotor will have to be spaced out an additional 5mm to split the difference. It would be easier to shim the caliper back but there's not that much room on the back of a 914 rear caliper. They can hit the arms (some would some wouldn't, depending on how they welded the adjustment access tube on your control arm). Fasteners also play into this; 7mm hardware is difficult to find, these need to be 10mm longer as well... then factor in they should work with both early and late style calipers (early style uses 11mm nuts and late has the front caliper half tapped). We wanted to supply a bolt-on system, no outsourcing on your end. 24 mm Rotors – It doesn’t apply and would be overkill for "most" applications. I say it “doesn’t apply” because once you’re up to that size rotor you’re “well beyond” the capacity of a standard 914 rear caliper (like trying to stop a merry-go-round with your hand). And, as you can see, there's a lot that goes into the spacing alone. A 14mm spacer wouldn't be the issue. The pins, rotor spacer and fasteners would all have to change. The standard 20mm rotor that stopped all 911's up to the Carrera is probably the best "all-around" option here. It was also done with Brad's new hubs in mind. A 911 vented rotor up front with an M-Caliper would be a perfect match for a V-Caliper with vented rears and a T-fitting. Furthermore... those who have bolted on a 911 front end (with the vented rotors) would simply bolt on a V-Caliper and vented rotors to have a perfect set-up for their ride (Aaron, Matt and Alberto are a few that come to mind). Royce, for a "street" car, I'm not sure if the minuscule unsprung weight is an issue but for some I guess it could be. The issue is cooler brakes. This caliper was thought of in the spirit of a well-balanced brake "system" to operate with the many M-caliper upgrades people have made with the 911 front end or Brad's hubs. I would use these with a T-Fitting and any front caliper "up to" an A or S-Caliper. Anything larger than that and I would suggest either 914-6 calipers with the GT spacers or an entirely new "system". Rotor Pricing: I have no allegiance here but the new Performance Products catalog has them listed for $64.95. That's the best price I've seen. |
Lo-Fi Version | Time is now: 5th June 2024 - 09:20 PM |
