This bushing is not my friend, Something always goes bad before AX |
eeyore |
May 13 2005, 11:18 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Yesterday as I'm adjusting the valves on my car I notice that something is a little off with the driver's side trailing arm. I reach up and wiggle it. The inside end of the trailing arm can move a quarter inch up and down (6mm for Sir Andy). Great, I have to replace the thing, and only one day to get new parts shipped.
I was under the car 2 weeks ago, fiddling with shim stacks and am quite sure there wasn't any problem then, so I suspect the problem was at the breaking point when I started the dual AX / DE weekend 2 weeks ago. It must have let go the 2nd day. So I guess I am saying, check bushings often if you still have originals. Many thanks to Ira Ramin (of Tarett) for getting me a set of replacement bushings tonight. NOTE: I did not move that broken bushing, that is how it came out of the car. Attached image(s) |
Aaron Cox |
May 14 2005, 12:12 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
shit. you have confirmed a fear of mine.
car was aligned. somehow a rear gained more neg camber..... inner fender well shows rubbing like above. GAWD DAMMIT. they are 1 year old. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 01:22 AM |
