This bushing is not my friend, Something always goes bad before AX |
eeyore |
May 13 2005, 11:18 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Yesterday as I'm adjusting the valves on my car I notice that something is a little off with the driver's side trailing arm. I reach up and wiggle it. The inside end of the trailing arm can move a quarter inch up and down (6mm for Sir Andy). Great, I have to replace the thing, and only one day to get new parts shipped.
I was under the car 2 weeks ago, fiddling with shim stacks and am quite sure there wasn't any problem then, so I suspect the problem was at the breaking point when I started the dual AX / DE weekend 2 weeks ago. It must have let go the 2nd day. So I guess I am saying, check bushings often if you still have originals. Many thanks to Ira Ramin (of Tarett) for getting me a set of replacement bushings tonight. NOTE: I did not move that broken bushing, that is how it came out of the car. Attached image(s) |
RustyWa |
May 14 2005, 11:08 AM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
So when you replace those bushings, do you just slap the new ones on or do you fit them to the trailing arm and spindle? Just curious. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:36 PM |
