Vac Advance, Is mine bad?? |
Tom73 |
May 15 2005, 05:39 PM
Member Group: Members Posts: 180 Joined: 20-September 04 From: Central Texas Member No.: 2,792 |
Working on the tune up and tested the vac advance. It will pull off like it should but then I hear a "pop" and it slowly goes back. Will not hold. Is it bad???
This is a '71 1.7. tom... |
McMark |
May 16 2005, 01:12 AM
I'm not sure I understand your description. But if your unit will not hold a vacuum, it is bad. You can suck on the vacuum hose to move it and plug the hole with your tongue. If you can see the advance plate move back to its neutral position, then it is bad. Best as I can understand, you've got a bad unit.
Lo-Fi Version | Time is now: 8th June 2024 - 07:17 PM |
