> Turn signals don't work, but everything seems wired correctly!
beemie96
post May 7 2005, 03:25 PM
Symptoms:
car off -- parking lights act as they should -- each side turning on depending on the turn signal stalk
-- also, the hazard switch will light up red and the exterior lights turn on, but they don't flash.
car on -- the dash indicators light up, the red light above the gas gauge lights up (the big one)
-- turn signals don't work, but they seem to TRY to work.
-- the weird part! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) -- turn on the parking lights and the flasher relay (the square one) starts buzzing! the headlights work and the parking lights light up.
-- another weird part! (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) -- start moving the slider around for the vent / defrost thing, and i'll hear the flasher click.
I've checked all the connections, even replaced the flasher relay and the turn signal switch. checked all the round relays (if that matters). all of them are good. all new bulbs as well. I haven't checked the license plate lights or the luggage / dome light. I'll do that in a minute now that I thought of it.
Sound like a short? no fuses are blowing... but something seems to be preventing the flasher from working properly... even though all the other parts look right. If it's a short, where do I start looking? (under the dash, i'm sure, but i was wondering if anyone has seen this behavior before and can point me in a direction)
beemie96
post May 16 2005, 06:25 AM
I heard that the MC was 2-wire on some cars, 1 on others. Mine had two.
That mean I have the 17mm MC?
beemie96   Turn signals don't work   May 7 2005, 03:25 PM
beemie96   Okay, for starters, is there a way to test ONLY th...   May 7 2005, 05:27 PM
beemie96   Another question : Can the ignition switch cause ...   May 7 2005, 11:30 PM
ablose58   sounds like a ground problem to me. Also check the...   May 7 2005, 11:33 PM
beemie96   yeah, it does sound like a ground problem, but i...   May 7 2005, 11:42 PM
ablose58   Check te ones right by the fuse panel!!...   May 8 2005, 12:20 AM
markb   This sounds dumb, but make sure the 2 wires are pl...   May 8 2005, 12:50 AM
beemie96     May 8 2005, 07:17 AM
Rand   Make sure the bulb contacts are clean. Corrosion o...   May 8 2005, 01:20 PM
mike_the_man   Another thing to check: I was having similar symp...   May 9 2005, 11:12 AM
beemie96   Got good suggestions from here and PP's forums...   May 10 2005, 06:42 PM
beemie96   Well, new flasher from Pelican was the trick. So,...   May 15 2005, 02:55 PM
Cap'n Krusty   Remember, there are TWO different flashers, 3 and ...   May 15 2005, 07:21 PM
xsboost90   there are two wires on the mc??? i put in a 19mm a...   May 15 2005, 07:51 PM
- Lo-Fi Version Time is now: 1st July 2025 - 06:13 AM
