Help! My Probe is too long for the taco., Taco Plate on a 1.8 |
cdmcse |
May 17 2005, 12:08 AM
Member Group: Members Posts: 340 Joined: 17-December 04 From: Georgetown, Ky Member No.: 3,305 |
I picked up a used taco plate and oil temp sender set-up off of evilbay with the intention of installing it on my 1.8. The sender that came with the plate is too long to fit into the engine. The plate fits fine, but the sender hits the block before the threads engage with the plate in either direction.
Do I just have the wrong sender or is it not possible to put that on a 1.8? Anyone know the part# for the right sender? Here are a few pics... Attached image(s) |
wilchek |
May 17 2005, 10:18 AM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
angle the plate a little to put it in. It will not go straight up. wire contact toward the firewall and the engine bar. tilt the taco plate with sensor installed (firewall side/engine bar side) down toward the ground an slide in and then flatten against block and bolt up. It should fit.
not the best pic but this is factory install Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:40 AM |
