> Adapter plate/Flywheel questions, KEP plate, bus flywheel
TonyAKAVW
post May 18 2005, 10:20 AM
That's my ride.
So I found a potentially good deal on an adapter plate and flywheel for my Subaru conversion. The adapter plate and flywheel in question were bought for putting a 2.0 Subaru motor into a bus. It seems that the adapter plate should be fine for use with a 901 transmission and a 2.5L Subaru engine, but I haven't been able to figure out whether the flywheel will work for me.
I don't know if its a 228mm flywheel or not and I suppose thats something I should have the seller measure, but lets assume that it is. What sorts of problems might I encounter with this? Are the ring gears going to match up or is te starter going to require some shims, or movement, etc.?
And about clutches. If I have a 228 mm flywheel I suppose I will be forced into using a bus clutch. Is this bad or good?
-Tony
scotty914
post May 18 2005, 11:47 AM
suby torque rules
well i dont know about the flywheel, but i would bet you could send it to KEP for a credit to a 914 one. i do know the bus clutch stuff is cheaper.
here is a question can he use a bus starter, i thought they were the same, or is it a bell housing thing. i just know when i got my kit it worked fine.
- Lo-Fi Version Time is now: 12th July 2025 - 04:23 PM
