Carb Timing Question, Backfiring... |
yarin |
May 18 2005, 05:09 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I'm trying to work on the timing on my car. I bought a Sears Induction Advance timing light and i'm going based on Pelican's tech articles. Basically the car backfires like crazy over 3k rpm at any decent load. I hooked up the light, i think i see the major 34deg mark on the fan.. is this the wide fan blade? Do I set the timing light to 27 degrees at 3k rpm and line up the large fan blade with the mark on the housing?
Anyhow, i changed the timing around a bit and it still backfires like crazy out the exhaust. It also huffs on the intake side here and there. I don't have any electronics to set the dwell. This problem came up after two autocrosses. Any ideas? Fresh plugs, cap, rotor and wires already done. This is my first time really getting into carbs so pardon my ignorance but I can't seem to find the "vacuum advance line"? Where would it come from and where should it connect to? Thanks! |
yarin |
May 19 2005, 10:48 AM
Thanks for the replies guys. Yes that is a rev limiting rotor. Not sure which dizzy i've got. I'm going to pickup a dwell meter today.
When i first brought the car home i took it up the road for a drive. The gas pedal bent and got stuck on under the sheetmetal, went to shift into 3rd and the tach shot to the right. After that the car wouldn't restart. Eventually it started again and ran for a while, but not without random ignition failures. 2 weeks later i found the old rev limiting tach mechanism in a few pieces sitting on the distributor. Ooops. Problem solved. When i put the good motor in i plan on going with an optical or magnetic points replacement. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:22 PM |
