| mikelsr |
May 19 2005, 09:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
I was in the process of reinstalling the shock nut when the tab on the strut mount support washer broke. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) This causes the shock shaft to just rotate. I inserted a 6mm bolt in the threaded hole in the shock to try and use that to help me be able to loosen the nut. It also broke. I can drill the broken bolt out of the shock and use an easy-out to get the bolt out, but I am stumped on a way to get the nut off without cutting the it apart. I am trying to find a nut cracker to do it.
I am thinking the tab got wedged in the threads and now I can't get it loose. I have a new support washer and nut for it once I get it off (or I get the new set of shocks I am wanting). Any ideas? Here is what it looks like (IMG:http://img.photobucket.com/albums/v41/mikelsr/914/shock-2.jpg) |
| Gint |
May 19 2005, 09:36 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Pneumatic impact wrench is the only way to go on something like that. It will usually zip 'em right off. And if I'm not mistaken, the large thick washer has a tab that fits into the groove in the strut shaft. So if the nut won't come off of the shaft without the shaft turning, secure the washer. Large (very large) pliers or even a pipe wrench will take care of that.
mikelsr Help with shock nut removal May 19 2005, 09:24 PM
mikelsr Thanks for the reply. I tried an electric impact w... May 19 2005, 09:46 PM
Gint How'd I miss that broken washer part? You... May 19 2005, 09:59 PM
mikelsr The pneumatic impact wrench worked like a champ. T... May 20 2005, 08:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 10:07 AM |
